#51
Re: Mavericks 10.9 & Mbox mini update still not working
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
#52
MacBook Pro 2.53 Ghz, Intel Core 2 Duo
4gb 1067 Mhz DDR3 OS 10.9.2 Protools Mbox 2 Protools 11.1.2 I've installed the latest driver (10.3.3) and manually deleted the files requested. Still, no audio output. I see the Mbox2 as an option in just about everywhere: IO Setup; Hardware; Playback Engine; System Prefs; |
#53
I am having the same issue. After downloading all new drivers and updating Mavericks my Mbox2 and my Mbox Mini both WILL play audio through Quicktime, but NOT through iTunes or Pro-Tools. This is a software issue that Avid needs to address.
MacBook Pro (2011) OS X 10.9.2 2.53GHz 8GB RAM Mbox 2 Mbox Mini Pro Tools LE 10 |
#54
Goodbye Avid, I've gone to Apogee.
#55
There hasn't been a proper fix yet, but a workaround that seems to work for some is using a cheap USB hub.
Joel
#56
Unfortunately, if there's not a proper fix soon Avid will be losing another customer. It's ridiculous that this has been going on for six months for some people.
#57
Late 2013 iMac
Mavericks 10.9.2 (shipped with it) PT 11.1.2 Mbox Mini (3) Mbox Driver 1.2 Problem: pt will not open or initiate a new session whilst the playback engine is selected to Mbox Mini PT opens any file if the playback engine is built in audio, then you switch the playback engine to Mbox Mini and the session works fine through the Mbox Mini All other audio applications work fine with the Mbox Mini Bigger problem is that I have 26 computers with this setup and 300 students in this facility and we are 7 weeks into term and there is still no fix being discussed on the horizon..... very close to putting Mbox Mini's in the bin. Identical workstation works 100% with Mbox 2 or Mbox 3 (non mini) Is there a PT update or Mbox Mini driver being worked on that addresses this issue? |
#58
I see that.. up until this moment, there is still no official fix for this... or is there?
#59
Fix for what? There is probably several different things going on for folks in this thread. Avid is not going to fix the known USB/core 2 CPU/Maverics problem with Avid drivers as has been discussed in other threads on DUC. The suggestion there is to try a USB hub. At this point Avid consumer Audio interfaces are amongst the last I would recommend to a purchaser. |
Mbox 2 mini not working after firmware update | dizzove | Tips & Tricks | 2 | 02-15-2015 11:46 AM |
Mbox mini 3rd generation PT 11.0.3 and Mavericks | Elnico50 | FireWire & USB Audio Interfaces (Mac) | 11 | 12-17-2013 04:54 PM |
Mbox 2 Mini and Mavericks - when is update coming? | Elnico50 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-02-2013 01:13 PM |
Mbox Mini (3rd gen) no sound on Mavericks | xeraphone | FireWire & USB Audio Interfaces (Mac) | 4 | 10-29-2013 09:11 PM |
Mbox 2 mini not working after firmware update | dizzove | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-23-2011 10:24 AM |
