Windows configurations problem
Hi there clever folk.
I have just discovered the wonderful delights of Windows configurations on my ProTools 8LE. The problem is, I can't get it to work across two monitors, with the mix window on the left, and the edit window on the right. I have checked the manual (and across this forum) but nothing I do seems to work. The windows configurations will only ever save changes on my edit window, and not the mix window. And don't worry, I have tried ticking both boxes when creating a new configurations, making sure the bottom box says mix window of course. I really want to utilise this brilliant facility, and I'm getting very frustrated with not being able to control it the way I would like. I am running ProTools 8LE across on Mac 10.6 with two ViewSonic monitors. Aaaaargh! |
Re: Windows configurations problem
Not sure about Macs but for Windows, you need to drag the edges of the parent window to fill BOTH monitors. Then, you can drag MIX and EDIT windows to the desired screen and drag the edges out to fill each screen.
Thanks for the reply. I think I have described my problem badly....
I have no problem with running two screens. It's the way that I've run my system from the beginning... ...my problem is with the specific "window configuration" capability, found in the WINDOW DROP DOWN MENU. I set up a BASIC VIEW named BASIC, then I set up a WINDOW CONFIG which I call HEDMIX, and this changes to view of my SENDS in my main mix window to just show SEND E which is how I configure it. I also have the SENDS showing in my EDIT WINDOW, so that I can stand at my mic and adjust the send levels getting bussed to my headphone mix. Brilliant.... ....but if I TRY to set up another CONFIG screen, for guitars, for example, I want the sends on both mix and edit window to revert to ASSIGNMENT VIEW, but with the added plug in on screen, like Amplitude. Well, I can do this, but when i try to go back to the HEDMIX CONFIGURATION, nothing changes....!!!!! It's like my WINDOWS CONFIG have forgotten what I set up before, as a BASIC set up, and the HEDMIX configuration. One of us is stupid......I think it might be me.......but I'm still not dismissing the PT8LE.......!!!!!!!! Again, I'm on PT8LE, Mac 10.6 |
10.8.4
11.1.2.214 10.3.8.378 2.66 Ghz Quad-Core Intel Xeon 16GB RAM - 1066 MHz DDR3 Audio Hardware - Coreaudio Aggregate MOTU HD Express & 828mk3 Hybrid ATI Radeon HD 4870: NVIDIA GeForce GT 120: I use window configurations routinely, and it appears broken in 11.1.2 on my system. I have 3 monitors, and typically use both my edit and mix window on the 2nd monitor (plug-ins, sends, etc. on the 1st monitor - video on the 3rd). No matter which way I save my window configurations now, when recalled, it places both the mix and edit window on the 1st monitor. I'm not sure if this helps, but the first monitor is the one that contains the Mac menu bar. Every time I open sessions, the windows open to that 1st monitor, even though they were saved with the windows on the 2nd monitor. |
Crumbs Farmer Dave, thanks for your reply.
I seem to have solved my windows configuration problem to a certain degree, and the only thing I can't get to save, is the actual view of my sends and assignments but that's not a major problem. The plug ins pop up just fine, and I found it to be an absolutely incredible time-saving shortcut. Like you, it also seems that the only things that WILL save, only save on the screen containing my Mac menu. In my case that is my edit window. Food for thought…! Sadly pro tools 11 is slightly out of my range of expertise, but have you tried running it temporarily on two monitors and see what happens then? Thanks again. |
If I save sizes and positions ON THE 1ST MONITOR ONLY, that saves and recalls correctly to the 1st monitor. Other monitors don't recall. |
I am having the same problem with pro tool 12.4 on OS X Yosemite.
Anyone ever fine a solution to this very frustrating problem? |
This topic has been discussed before - do a search of the forums. For me, if the second monitor's window is stretched to fill the entire screen, then when the session is reopened it gets moved to the first screen, usually behind the other window. The only way I can get it to stay where it should is to have it slightly shy of filling the whole screen. Sometimes you also have to hit the green fullscreen button and back a couple of times. And then sometimes even THAT doesn't work and I have to move the window to the correct screen, make it very small, save and reopen the session, then enlarge the window - but not all the way to the edges. Never had this problem on pc.
Very annoying that this is still an issue with PT12.6.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Just a shot in the dark, but have you selected "auto-update" in the window config menu ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
I've just updated to 12.5 same problem. I set up a config with mix on one screen & edit the other & save them & then when I select them from windows config menu & both edit & mix windows just end up back on the Raven screen! Soooo FRUSTRATING !
Sent from my iPhone using Tapatalk |
Windows configurations screen weirdness/flashing when selecting | crizdee | Pro Tools TDM Systems (Mac) | 2 | 03-28-2014 02:19 PM |
PT 11 not saving windows configurations correctly | garnoil | Pro Tools HDX & HD Native Systems (Mac) | 1 | 11-19-2013 12:24 AM |
ELS Vocoder plugin problem and fresh Windows 7 install problem | Thorpey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-09-2011 05:03 AM |
Window Configurations and track views problem | Skyflash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-14-2007 09:57 PM |
windows hardware configurations for Mbox | neils | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-09-2002 02:43 AM |
