Old 07-05-2021, 06:53 PM
dez811 dez811 is offline
Default 2021.6 freezing on playback
Since upgrading to 2021.6 I have noticed the pro tools freezing and not being able to do anything with the mouse for a few seconds then it goes back to normal, this is always during playback but it never crashes audio doesn't skip. Sometimes when trying to move a knob or fader on a plugin it happens too, the session is at 24/48k and cpu meter tops out at 41%. I'm on Catalina, MBP 2016, 16gb ram, 2tb ssd and record to an external ssd
Old 07-05-2021, 08:33 PM
seebee62 seebee62 is offline
I had the same behavior with 2021.6. I’m on a M1 Mac Mini. All previous version of PT were butter. I went back to 2021.3 and I have none of those issue. Every thing is smooth and easy.
Initially I figured 2021.6 wasn’t playing nice with M1 but if you get the behavior on Intel something is up.
Sent from my iPad using Tapatalk Pro
Old 07-06-2021, 09:01 AM
dankin dankin is offline
Default Re: 2021.6 freezing on playback
2021.6 is a mess here. I get the momentary freezing even when saving a plugin preset.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII
Old 07-07-2021, 06:49 PM
Malkout Malkout is offline
Same here with Big Sur, Mac mini M1 highest specs!
Old 07-07-2021, 07:26 PM
nsureit nsureit is offline
I had the same issue. However, since I began turning off Wi-Fi while using Pro Tools, it has not happened again. I use an iLOK dongle on startup.
Old 07-07-2021, 09:04 PM
My WiFi is off but I’m connected to Ethernet
Old 07-08-2021, 03:29 AM
weezul weezul is offline
Same here. And I don't think it's an internet issue as I'm on Ethernet, and with Little Snitch blocking Pro Tools from connecting anywhere. Even with little snitch disabled it's still the same. Very annoying, looks like I have to sacrifice tab to transient working to avoid the problem, or even go further back.
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 07-08-2021, 04:06 AM
I went back to 2021.3 , That was much much faster and I hadn’t any issue
And i have noticed one thing, while bouncing offline, the speed become half like x20. When downgraded to 2021.3, speed becomes x43 again
Old 07-08-2021, 08:04 AM
Noticed that while freezing it effect the delay compensation also, be aware!!
Old 07-08-2021, 10:20 AM
I had the slow offline bouncing/committing speeds with 2021.6 as well.
PT 8.0.4 cs2 Freezing during playback Julia B Pro Tools M-Powered (Win) 2 12-13-2010 11:52 AM
PT 8 freezing on playback AdamThompson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-12-2009 08:43 AM
Freezing during playback finalcut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-05-2005 10:38 AM
PT Freezing on Playback dwdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-20-2003 10:24 PM
Freezing in playback roderickelms Digidesign Hardware & Software 2 11-04-1999 07:48 AM
