Old 04-03-2021, 08:02 AM
songman songman is offline
Default deleting part of audio file
I've recorded a long audio file and removed a middle part of its clip on its track. However what I want is to remove the real audio file in the audio files folder and replace it with two audio files of the remaining two parts of the long audio file corresponding to the two remaining clips. How do I do that?
Thanks, cheers, Bob
Old 04-03-2021, 12:12 PM
Ben Jenssen's Avatar
Default Re: deleting part of audio file
Several ways; but if you really need a session folder with minimum files, "save session copy..." is easy:
- select the clip(s) and "consolidate" in file menu, so that new files are created for these clips.
- go to clip bin, select unused clips in clip bin menu and remove them.
- with only the two newly created files left in the clip bin, save a session copy.
Close the session without saving.
A new session folder with only the two files is now there, and you can delete the old one of you like.
Old 04-04-2021, 01:34 AM
Thanks a million Ben, that is exactly what I needed. Works like a charm.
Cheers, Bob
Old 04-04-2021, 02:02 AM
Anytime.
MIDI notes still there after separating and deleting part of clip SigFriedChicken Pro Tools 12 12 12-09-2017 08:22 AM
Mac version of .bat file for deleting preferences? SixChurchStreet macOS 2 04-19-2011 03:10 AM
Selecting part of a file from Browsers idris Post - Surround - Video 10 10-12-2010 07:19 AM
Part File Type Confusion With Structure RussUK Virtual Instruments 1 11-27-2009 09:47 PM
deleting part or all of a track dlap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-25-2009 03:16 PM
