Old 10-26-2014, 07:02 PM
jpmorgan jpmorgan is offline
Default how can I get ProTools 10 to load Komplete 10 plug-ins?
I just purchased and installed Komplete 10 from Native Instruments, and I'm trying to learn how to use virtual instruments. Since I'm doing mostly classical music for the time being, I'll be working primarily with the VSL orchestral samples included in Kontakt 5.
First question: How do I get the the Kontakt 5 instrument packages to appear in the Inserts A - E of an Instrument track in ProTools 10?
After I installed Komplete 10 and opened ProTools, I got a pop-up entitled "Move Unauthorized Plug-ins" that listed all of Komplete 10's AAX plug-ins, and stated "ProTools could not load the following plug-ins either because no valid authorization could be found, the iLok key was not connected, or the plug-in was damaged." What is meant by "valid authorization", and where is it supposed to be found? My iLok key is connected, and I don't have any way of knowing whether or not the plug-ins were damaged. (I'm assuming they weren't, since the installation went smoothly.) After a successful installation, only the standard plug-ins included in ProTools are offered as inserts.
Old 10-26-2014, 11:40 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: how can I get ProTools 10 to load Komplete 10 plug-ins?
Most likely the NI AAX plugins are 64-bit only, which means they are meant for PT11
As you have PT10 which is still 32-bit it means you most probably will need to install RTAS versions of the plugs instead of AAX.
Janne
Old 10-27-2014, 12:32 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Use NI's service Center and authorize your computer to your NI account
Old 10-28-2014, 06:09 AM
In addition to that run each of the instruments in standalone mode before running in PT.
You'll probably also find that when you run Service Center that there are updates for your NI plugins. More likely than not what's on the dvd's is NOT the latest version and that's normal for NI or any other developer that does dvd distribution.
One thing you will find is that there is no longer RTAS support from NI because when they came up with the Komplete Kontrol thing that also dropped RTAS install. If you have an old install of Komplete it will not overwrite or delete the RTAS plugins.
Jack
QAPLA!
Old 10-28-2014, 12:17 PM
songman songman is offline
I am running Komplete 10 Ultimate on Protools 10. All plugins are the AAX versions and they are all running fine. There is no reason why the AAX plugins should not run on PT10. I am on a MacPro 2x2.93 GHz 6core +24 cores) Intel Xeon with 24 GB RAM and OSX 10.8.5. Protools is 10.3.7 and I have an HD3 Accel system. Update all your plugins via NI's service centre, it should work.
Cheers, Bob.
PS I am assuming you activated Komplete 10 via service centre? Otherwise of course none of the software will work.
Old 10-28-2014, 07:27 PM
I have Komplete 10 (not Ultimate), and I'm using Windows 7 Ultimate. My version of Protools is 10.3.2. My computer has an I-5 core, and 8 GB of RAM. After I had installed Komplete 10, and I opened ProTools, a pop-up appeared titled "Move Unauthorized Plug-ins". It lists the AAX plug-ins in Komplete 10, and aks you if you want to move these plug-ins to the "Plug-Ins (Unused) folder". I didn't know how to answer this question, so I just clicked the pop-up off. Should I have answered Yes? If so, how do I get that pop-up to reappear?
Old 10-28-2014, 07:38 PM
Southsidemusic's Avatar
Hey
Did you check this post as it seem to have helped others
http://www.native-instruments.com/fo...ols-10.228025/
Best Regards
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 10-29-2014, 12:06 AM
All this seems to me to be very strange. Having to go to 10.3.9 (beware of THE bug in 10.3.9!) to have your NI stuff running. It runs fine in 10.3.7, both version 9 for over a year and now just recently version 10. So there has to be something else that is not OK. Try downloading the updates, try opening a few items in standalone mode first, and then try again in protools.
Old 10-29-2014, 09:06 AM
mesaone mesaone is offline
Looks like the solution in Christopher's post is to start each instrument in standalone mode, and register it from there. Not sure how this will affect the non-instrument plug-ins, though.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 10-29-2014, 09:18 AM
No. The way to do this is to register everything through NI Service Center first; download any updates; apply the updates and then run each vi in standalone mode first with Service Center closed. Does not apply to the effects though as with the exception of Guitar Rig 5 none of the others will run in standalone mode.
Long time NI user (back before there was Komplete anything) so this isn't my first rodeo.
Jack
QAPLA!
HTML code is On
Komplete 9 and Protools?? abre Pro Tools 10 3 05-02-2013 11:44 AM
ProTools LE 8 and Komplete 8 mattilda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-13-2013 02:51 AM
Installing Komplete 7 deleted my plug in alias PT HD wont load mafiacondon Pro Tools TDM Systems (Mac) 2 09-16-2010 10:06 AM
ProTools 8 Fxpansion VSTs "The plug-in failed to load" balveniediggz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-27-2008 09:30 AM
how to load plug-ins in protools? kickstand22 Virtual Instruments 1 10-24-2006 11:21 AM
