Old 10-06-2014, 01:08 PM
Royce88 Royce88 is offline
Default Consolidating creates strange clicks/pops in rendered audio region?
Greetings,
Has anyone had an issue where consolidating a track created strange clips / clicks within the rendered audio file?
Is this a bug of some kind? Sometimes I would undo the command, and re-do the consolidate until those clicks aren't rendered anymore. But it would be hassle to have to keep checking entire tracks over and over again after every consolidation just to make sure those glitches didn't get rendered.
I'm running PT 11.2.1 with OSX 10.9.5 using a UA Apollo interface.
Thanks for any advice!
Old 10-06-2014, 01:18 PM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
Default Re: Consolidating creates strange clicks/pops in rendered audio region?
I get this on and off when consolidating a track with a lot of cross fades. Hasn't been bad in the latest vs of PT. But I usually just buss the track over to another in real time.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 10-06-2014, 01:55 PM
Thanks for the feedback! It's an unfortunate bug that certainly could cause some major troubles if you didn't notice the error as soon as it appeared. Consolidating is such a big part of my work flow, and this bug seems to just pop up randomly.
Old 10-06-2014, 02:21 PM
cwsand's Avatar
cwsand cwsand is offline
Interesting, I've never had this issue with crossfades and consolidating. Can we confirm that the clicks and pops occur at the point of the crossfades? Is there actually a crossfade at that point, or a failed crossfade where there's only a fade out/in on one clip and the other clip starts or begins cold?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-07-2014, 08:56 AM
Those issues didn't necessary pop up at crossfade points. Will have to see if a pattern comes up with these rendering issues in PT.
Old 10-09-2014, 04:07 AM
huzzam huzzam is offline
I remember running across this often with Elastic Audio tracks at some point, though I don't remember anything recently. Might have even been back on 10... Are the affected tracks Elastic by any chance?
~peter in istanbul
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 10-09-2014, 04:46 PM
DAWgEAR's Avatar
DAWgEAR DAWgEAR is offline
I have experienced this. Someone mentioned this happening as a result of using 32- bit float for the bit depth. I had been using 32-bit and 96k. I subsequently converted to 24-bit and 96k and I have not noticed it since. The switch to 24-bit may or may not have anything to do with my experience.
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1
Old 10-30-2014, 12:45 AM
Thanks for the replies. It still seems to be an issue. Haven't really narrowed it down to what may be the cause. This glitch just literally causes a sudden audio clip in the consolidated region. And it doesn't occur over a warp marker or fade.
I now I have to consolidate, undo, consolidate, undo, and consolidate again until I don't see any of those strange artefacts.
If anyone has further insights, would be appreciated!
Old 10-30-2014, 12:48 AM
JFreak's Avatar
JFreak JFreak is online now
I've been using 96k 32float lately and have never experienced this, not ever.
Janne
Old 10-30-2014, 01:48 AM
Farhoof's Avatar
Farhoof Farhoof is offline
I've only experienced any consolidate bugs when my bin is sorted by 'modified date' (older regions removed from the timeline ended up in the consolidate). Sorted alphabetically always works on my rig.
Strange Pops and Clicks philrecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-24-2005 04:43 AM
clicks when consolidating audio francois Pro Tools TDM Systems (Mac) 21 02-15-2005 10:10 PM
Clicks and POPs when Consolidating Beat Detective Mike Landolt Pro Tools TDM Systems (Mac) 3 06-08-2004 11:30 AM
Clicks & Pops in Audio. roberts Pro Tools TDM Systems (Mac) 2 01-25-2004 10:14 AM
strange pops & clicks since 5.1 upgrade.. Mike F 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-10-2001 05:18 AM
