Old 10-26-2013, 12:11 PM
michael c michael c is offline
Default RTAS vs AAX
When using PT10HD, is there any difference in using RTAS versions of plugs versus AAX? Any advantage? I'm not sure we want to hunt down AAX version plug-ins of our RTAS.
When it comes to DSP / TDM plug-ins, do we need to upgrade to AAX versions?
Thanks.
Old 10-26-2013, 12:19 PM
Drew Mazurek's Avatar
Default Re: RTAS vs AAX
Thanks.
Unless the developer made changes when upgrading RTAS plugs to AAX 32bit, there isn't much/any differences. I have seen some people saying AAX is more efficient but I haven't noticed.
As for TDM, PTHD 10 is the end of the line for them. So, you'll either be staying on 10 or "upgrading" to an HDX card which means you'll need AAX DSP versions of your TDM plugs if you want them to still be DSP based. Otherwise, it's all native.
www.drewmazurek.com
Old 10-26-2013, 12:42 PM
We realize that TDM is dead on 11, but in 10 with TDM, do you have to have AAX version of the DSP plugs to run in 10HD, or are the version PT 8/9 DSP TDM plugs compatible in 10HD.
Thanks.
Old 10-26-2013, 12:50 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
HDX cards are not compatible with TDM. HD and Accel cards are compatible within PT 10 but not 11
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 10-26-2013, 12:56 PM
I know that as well, just trying to figure out if our existing plug-ins in PT8/9HD that are TDM, will work in PT10HD with our existing system which is an HD3.
Old 10-26-2013, 01:00 PM
Craig F Craig F is offline
Most should but you should check if there updates for 10 TDM, AAX DSP will not load onto the HD cards
Thank you,
Craig
Old 10-26-2013, 02:33 PM
Eric Lambert's Avatar
Every single TDM plugin I have works fine in PT10HD.
Old 12-29-2013, 10:37 PM
blumuze blumuze is offline
I'm about to upgrade to PT 11 from PT 8. Is it possible to install every AAX version of my plug-ins before I install PT 11? I mean, will the AAX plugs work in PT 8? If so, and if I install them before PT 11, will I have to reinstall them when I install 11?
Deja Vu is a slow mind catching up with itself.
Old 12-30-2013, 12:04 AM
No, 8 can not use AAX
You will need to install afterwards
Thank you,
Craig
Old 01-08-2015, 09:26 PM
AMIEL AMIEL is offline
Default RTAS or AAX by default which one PT 10 open?
when a plug in installs RTAS and AAX in PT HD 10 and because both are native... which native version open PT 10 by default???
is always the same?? or depends from manufacturer??
Thanks!
Reuven Amiel
Mixer/Producer.
HTML code is On
Is there a way to convert vst to rtas without vst to rtas adapter? rockguitarist1255 Pro Tools 10 9 01-11-2012 08:35 AM
Why can't I monitor RTAS on Insert A? Line6 Gearbox RTAS Justin1524 Pro Tools TDM Systems (Mac) 3 05-12-2007 07:44 PM
TDM RTAS Vs Native RTAS joybeanstudios Pro Tools TDM Systems (Mac) 7 05-09-2007 09:33 AM
McDSP / HD RTAS vs Native RTAS tclash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-01-2006 08:01 PM
Ozone with wrapper?? or rtas- T-racks RTAS ???? Camilo Toledo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-14-2004 06:35 AM
