Plogue Bidule does not show up as Rewire in PT 11.0.1
Just installed the latest Plogue stand alone 0.9732 and i don't see it listed in the instrument list in PT 11.0.1...any idea ?? Thx
Re: Plogue Bidule does not show up as Rewire in PT 11.0.1
Open the standalone version of Plogue, and in preferences->rewire make sure the "enable rewire mixer" box is checked. You can also set the number of available audio channels and rewire midi ports here.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
it was already checked...any other suggestions ?? thx
Do you have any other rewire apps like Reason, Reaper, sibelius etc? Do they show up in the instrument list? I remember running into this problem a few years ago, but I can't remember what the cause of it was. Make sure you fully quit plogue bidule standalone before launching pro tools.
Turn off the "Run in 32bit" that's now default.
App>get info>Uncheck the tick-box.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Did all the above already before posting this question...
Finally found the problem...it's PT related. Anyways...BIG thank you to Seb at Plogue...here's the solution just in case anyone comes across this issue: <<I figured out the issue, this is a major bug with Pro Tools 11. ReWire devices are only scanned when the DigiReWire plugin is scanned (which typically happens when running a new Pro Tools version). Any ReWire device installed after that scan will never show up in Pro Tools 11 until a new plugin scan occurs. On OS X this can be forced by manually deleting the file name InstalledAAXPlugIns in <your user>/Library/Preferences/Avid/Pro Tools >> |
Thanks for posting your solution.
Plogue bidule | woodsdenis | Pro Tools TDM Systems (Mac) | 14 | 05-14-2009 07:17 PM |
Plogue Bidule & PT7.3 in Rewire - CRASH | blizzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-25-2009 10:21 AM |
PTMP Freeze with Plogue Bidule ReWire? | organik | Pro Tools M-Powered (Mac) | 0 | 01-16-2006 09:49 AM |
Plogue Bidule, Pro tools 6.4 & Rewire | who | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-24-2004 06:51 AM |
Plogue Bidule | sleepingtiger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 07-18-2004 10:27 PM |
