Old 05-30-2012, 12:18 AM
oplatner oplatner is offline
Default Eleven rack with another interface ?
hi,
is it possible to connect 2 different audio interfaces to pt 10 ?
my idea is to record with the 11r and mix with a different interface.
also, is it possible to record with 2 different interfaces at once in pt 10 ?
Old 05-30-2012, 04:00 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven rack with another interface ?
You can try aggregate on Mac.
But if you are going to record with one interface, then mix with another, there is no reason to fuss with it. Just change the interface in Setup when you want to switch.
You could also set one interface as the Main interface (your mixing interface) then hook up the 11R to the main interface via Digital.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 05-30-2012, 04:04 AM
hi,
i have the mbox mini 3, it has no digital inputs ...
Old 05-30-2012, 04:13 AM
Benoni's Avatar
Originally Posted by oplatner View Post
hi,
So just do as you were planning and switch interfaces when it comes to mixing. Or just use the Eleven Rack for both recording and mixing.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 05-30-2012, 04:20 AM
i will be glad to use the 11r for both,
but what i don't understand is: if the volume knob on the 11r is used for leveling the input gain while recording in pro tools, would't it effect the overall volume output of the whole session to ???
also, is it possible to bypass all signal processing ( effects/amp modeling ect. ) while playing back a pro tools session or just listening to mp3 track ?
Old 05-30-2012, 04:31 AM
Benoni's Avatar
The main volume knob is not an input volume knob, just output, and you can choose several different settings for how the volume knob works.
Also playback of a session or other sound source does not go through the Rig (amp, effects, ect...) The Rig is an input, the Main's are an output. And you don't route Windows Media Player, itunes, internet browser ect... through the rig, you route it to the mains, you don't have to bypass anything.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 05-30-2012, 04:35 AM
thank's for the info man !
so how do you adjust the 11r input gain during recording ( not through the channel fader i hope... ) ?
one last question: i'm thinking of positioning the 11r pretty far away from my pc, and want to buy a 5-10 meters USB 2.0 cable. does the length of the cable can degrade the sound/recording quality ?
Old 05-30-2012, 05:09 AM
Benoni's Avatar
You don't need to adjust the input gain of the guitar/bass itself through the "guitar input" port. If you want to increase the output of the rig then there are a few ways depending on the sound you are going for, such as you may want to increase the master on the Amp itself, or increase the Amp Out volume, but to raise the overall level, raise the rig volume.
USB2.0, as far as I can tell, has a maximum recommended length of 5 meters or less.
http://en.wikipedia.org/wiki/USB#Cabling
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 05-30-2012, 05:11 AM
acmost acmost is offline
hi,
Why not just plug straight into 11 and out into your interface like it's a separate Pre Amp? You can still use the 11 GUI(if you're using Pro Tools) that is.
Old 05-30-2012, 05:29 AM
Benoni's Avatar
because that's another A/D conversion. But it will work.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Eleven Rack as Interface Dopamine macOS 10 02-02-2013 11:35 PM
trouble using eleven rack as my interface tgalla macOS 2 07-22-2012 11:47 AM
Eleven Rack user interface gone ! hankbalony Eleven Rack 9 02-27-2012 09:30 AM
Eleven Rack vs. Eleven Rack to another interface petesteen Eleven Rack 1 02-05-2012 02:53 PM
Eleven Rack + Another interface? Kaigne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-01-2009 06:49 PM
