Old 09-15-2011, 08:17 PM
ericlawrence ericlawrence is offline
Default Pro Tools 9.0.5 won't authorize because it can't detect iLok
I recently switched from PC to MAC and Pro Tools 9 is not working on my new iMac (3.4 GHz i7, 16GB Ram, 1TB HD). When I first installed Pro Tools, and its most recent update (Pro Tools 9.0.5), it worked just fine which was good news because on my PC I kept having problems with Pro Tools not reading the iLok and therefore saying I didn't have authorization to open the program. I was so happy that I didn't have this issue with my new computer. However, that quickly ended and after one session I am again being told that I need to authorize Pro Tools, but for some reason it cannot read my iLok. The iLok is plugged in, I downloaded the most recent drivers and the blue light on the device is indicating that it is working. But for some reason Pro Tools does not recognize that it is plugged in. I have tried everything I can think of, but being new to Apple products I don't know the ins and outs of where things like drivers etc. are downloaded to and therefore cant tinker or troubleshoot. Please let me know what to do, how to fix this or what to change I need to get into Pro Tools asap! Thanks!
Old 09-15-2011, 09:52 PM
Jiffzillla Jiffzillla is offline
Default Re: Pro Tools 9.0.5 won't authorize because it can't detect iLok
I know it sounds strange, but if you haven't done so already, switch the USB port that you're plugging the iLok into. Also, if you're plugging the iLok into the USB port on the keyboard itself, it'll cause problems. (If it reads at all.) Hope this helps.
Old 09-16-2011, 05:32 AM
hoss33 hoss33 is offline
Recently I have had this problem, too.
It was not a Pro Tools problem as www.ilok.com did not see my iLok as well, only after a restart. Then it worked and after a few hours it did not again.
I reinstalled the latest iLok drivers twice (!) and have no problem since the second attempt.
Old 09-16-2011, 06:34 AM
The Dougfather The Dougfather is offline
Theres a new update from ilok, all of a sudden ilok decided it couldn't see my ilok this week when i was trying to synch and nothing has changed in 12 months on my system.
The update sorted it.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
New iLok Software doesn't detect any Authorizations on Gen 1 iLok Key TriAxis General Discussion 0 06-14-2013 11:20 AM
Pro Tools quits unexpectedly evertime i try to authorize it with ilok key dheinritz1 Pro Tools M-Powered (Mac) 3 01-06-2011 05:52 AM
Pro Tools cannot authorize iLok license jrgwynn Pro Tools M-Powered (Win) 12 07-30-2010 07:14 PM
ilok authorize 7.3.1.cs2 soltwej Pro Tools M-Powered (Win) 2 04-28-2007 06:06 PM
iLok required to authorize Pro Tools HD 7 softwar whtrabit Pro Tools TDM Systems (Mac) 8 10-07-2005 04:53 PM
