Old 08-30-2008, 10:06 AM
BarryBianco BarryBianco is offline
Default Projectmix line output configuration
I will be purchasing an outboard preamp and will be inputting through the line inputs on the project mix. When I do this, will the inputs still pass through the projectmix preamp stage in any way and possibly pickup noise from the projectmix electronics or will the signal bypass the preamps completely?
Old 09-23-2008, 11:18 AM
Bass1968 Bass1968 is offline
Default Re: Projectmix line output configuration
I'm pretty sure the line inputs run through the preamps.
Get an AD device and run your outboard gear through SPDIF or ADAT optical.
ProjectMix I/O Output assign question Kafrifelle Pro Tools M-Powered (Mac) 3 08-09-2010 09:59 AM
Projectmix Audio Output ARRRRGGGGGHHHHH! lucasbranf Pro Tools M-Powered (Win) 1 03-09-2008 12:47 PM
Projectmix Line Inputs J Neill Pro Tools M-Powered (Win) 0 09-19-2006 10:14 PM
ProjectMix 1/4" Inputs Truly Line Level ? 2012 Pro Tools M-Powered (Win) 0 07-05-2006 09:10 AM
ProjectMix line inputs -10? colt45 Pro Tools M-Powered (Mac) 82 05-27-2006 10:11 AM
