Projectmix only allows 2 inputs
I just got a M Audio Projectmix i/o and I am upgrading from an Mbox2 so I installed Mpowered and I got everything synced up and working with Mpowered and my projectmix except that when I go to select an insert in pro tools it only has 4 options, input 1, input 2 and S/PDIF.L and S/PDIF.R. Is there an option or something I need to change so I can have the choice of all 8 mic pre inputs?
Re: Projectmix only allows 2 inputs
You need to reset your I/O setup.
Go there, select all - delete. Then load defaults
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
thanks a ton man, that was simple and fixed my problem
Ok, my problem is that I can't get S-PDIF to be recognized by PTs as an option...it's italicized and says n/a, for the path. How can I get S-PDIF to be recongnized by PTs, and I guess by my M-Audio. I went to the Projectmix, mixpage and S/PDIF is selected...but PTs won't recognize. Thanks
The analog inputs seem to work.. |
Did you change the sync source in the Project Mix (software) control panel - under the 'hardware' tab? Needs to be set to external, from what I understand.
PT HD 10.3.10 M-audio hardware MacBook Pro Retina running Yosemite 10.10.5 MacPro 1.1 running Snow Leopard 10.6.8 all powered by Coffee |
Have you created S/PDIF paths in the I/O setup panel?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Projectmix Line Inputs | J Neill | Pro Tools M-Powered (Win) | 0 | 09-19-2006 10:14 PM |
Projectmix Inputs.. balanced or unbalanced? | edgarbc1 | Pro Tools M-Powered (Mac) | 0 | 08-14-2006 10:28 AM |
projectmix inputs | messenger | Pro Tools M-Powered (Mac) | 2 | 07-27-2006 11:39 PM |
ProjectMix 1/4" Inputs Truly Line Level ? | 2012 | Pro Tools M-Powered (Win) | 0 | 07-05-2006 09:10 AM |
ProjectMix line inputs -10? | colt45 | Pro Tools M-Powered (Mac) | 82 | 05-27-2006 10:11 AM |
