Old 12-06-2005, 09:18 PM
PTGuy PTGuy is offline
Default Help with monitoring/metering issue
Today when I was tracking even though nothing in the chain (meter wise) showed clipping I was hearing clipping through the monitors. The mic pre showed a good signal but no clip, the A/D showed good and no cliping, the 192 and PT mix window showed good signal and no clipping but when I would push it a little bit harder it would distort REALLY bad. I would get in the yellow but never in the red and no clip lights anywhere.
Any ideas?
Old 12-07-2005, 12:11 AM
Andre Knecht Andre Knecht is offline
Default Re: Help with monitoring/metering issue
A plug-in perhaps?
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 12-07-2005, 12:22 AM
Stig Eliassen's Avatar
I must ask...what do you push a little bit harder?
Old 12-07-2005, 02:14 AM
crizdee's Avatar
crizdee crizdee is offline
Any ideas?
Are you monitoring pre or post fader?
Chris
Producer, Engineer,
www.ukmastering.com
Metering Issue abre Pro Tools 10 0 01-10-2013 01:14 AM
Input monitoring and pre fader metering PROCHIC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-27-2010 04:52 PM
D Control Metering and Monitoring mmillten ICON & C|24 3 02-01-2008 01:29 PM
PT 6.4 Monitoring, Metering and other issues... Mt.Everest Pro Tools TDM Systems (Mac) 0 06-14-2004 11:46 PM
MBox / Dorrough Metering Issue clyde2000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-13-2003 06:41 PM
