Old 03-12-2019, 04:33 AM
songman songman is offline
Default 10.3.10 v 10.3.7
I'm running 7. Pretty fine, but have the regular "running out of memory" warning and a few crashes now and then. Is it worth it to go to 10? More stable?
Old 03-12-2019, 06:42 AM
Default Re: 10.3.10 v 10.3.7
no
Old 03-12-2019, 01:48 PM
crizdee's Avatar
crizdee crizdee is offline
Run Activity monitor > memory usage. all the time
Details here...
https://www.macworld.co.uk/how-to/ma...m-mac-3681038/
And when PT shows 3GB or just above then run memory cleaner app...
https://itunes.apple.com/us/app/memo...ign-mpt=uo%3D8
Some processes don't release the memory after use and it builds up to levels that exceeds PT's ability to run without error messages. but running activity monitor and viewing the memory usage you can see when its approaching the 3GB area then clean. PT can usually go to about 3.4GB but after 3GB it can show errors.
I found some plugins will use memory when opened and won't release the memory back for use, so memory cleaner will release this un-used memory back to the PT pool etc
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-13-2019, 02:07 AM
Thanks a lot for the replies and for the good info and suggestion Chris! Very much appreciated, will put it into operation right away.
Cheers, Bob.
Old 03-13-2019, 02:23 AM
Oops, I am still on 10.8.5 (last os to run PT HD 10) and the memory cleaner app requires 10.10.
Old 03-13-2019, 02:46 AM
crizdee's Avatar
I'm on 10.8.5 and use one called imemory cleaner but i couldn't find it and think its finished. just look for a memory cleaner that works on ML
I'll check later when im in the studio and confirm what i have and see if its still current
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-13-2019, 03:24 AM
Hi Chris,
I just downloaded two small apps from the app store (about 1$ each) which both seem to work OK on 10.8.5
Memory Optimizer and Booster by cokesoft
and Free Memory by ftosoft.
I think I prefer the first one, seems to do the job.
Thanks again for the help!
Cheers, Bob.
Old 03-13-2019, 07:19 AM
Southsidemusic's Avatar
#cokesoft ...
Who thought up that name and was like ”Yeah” !!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-13-2019, 11:37 AM
crizdee's Avatar
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-25-2019, 03:25 AM
fm_xtk fm_xtk is offline
Hi Chris,
Cheers, Bob.
Or you just quit and re-start PT. It is what I tend to do when it happens. It's pretty rare for me but usually starts at around 2.8GB
2x Hackintosh X79
HD7 Accel PCIe, Magma EB7 chassis
PT 10.3.10 Mac OS 10.9.5
SSL Delta Link HD 160 I/O
COCKOS REAPER (latest)
RME MADIFX (192 I/O)
ProControl (32 channel)
