Old 03-23-2015, 05:05 AM
Tim R. Tim R. is offline
Default Re: new MacPro for post work
Originally Posted by laki View Post
Hi Tim,
We were using RX Dial Denoiser in Auto mode (it actively learning and noise reducing) and it seemed like it wasn't tracking properly, dialogue would start off low and then eventually get to where it was supposed to be. Like the NR was set to max but then it realized that it needed to be some where else after a second or so. Like I said, we never tried to track it down. It was during an early stage of the mix and instead of trying to figure it out (no time) we just ditched it and everything worked fine. Sorry I can't be of more help than this. -L
Ah.. Gotcha. Auto mode was problematic for us as well. Mainly when trying to do a real time punch in on a mix since it is in constant fluctuation, it was never quite in the same place for the punch. We are running in manual mode without any issue. I think they've improved the tracking in auto since early versions as well. Might be worth revisiting.
Thanks
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Old 03-23-2015, 09:19 PM
dr sound's Avatar
dr sound dr sound is offline
You can't use RX Dialog Denoiser in "Auto" mode no matter what Mac you have.
Try this instead:
Highlight a clip with Denoiser set in "Auto"
Put your PT Automation in "Suspend"
Play this clip and let RX in "Auto" analyze the clip.Now when its's near the end of the clip flip it over to "Manual". Now keep looping the clip and adjust it to where it sound good (Level in/ out , amount of Noise reduction etc.)
Now stop the clip with it still highlighted and do
Command Option / (Backslash) Hold down all 3 keys simo
You have written the automation like you would any Eq etc . Now everytime it plays back it will be playing back denoised Dialog exactly the way you wanted it to sound. If you play it back in "Auto" it takes a moment to analyze the clip and that is why it doesn't sound good or you say "It gives me trouble". Don't buy a New Mac, just optimize your workflow for the Tools you are using.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
HTML code is On
MacPro 2.8 QuadCore will it work with PT 11 Joe Egan Pro Tools HDX & HD Native Systems (Mac) 10 05-23-2014 12:15 PM
Using carbon copy to move from macpro to a newer Macpro fourthtunz Pro Tools TDM Systems (Mac) 2 04-10-2012 02:39 PM
Two Graphics cards in an Intel MacPro 8 Core for Post joepopp Post - Surround - Video 5 10-23-2007 04:05 PM
Macpro HD1 in post production soundworx Post - Surround - Video 3 03-19-2007 03:28 AM
MacPro HD1 in post production soundworx Pro Tools TDM Systems (Mac) 1 03-18-2007 08:25 AM
