Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 02-10-2021, 06:41 PM
Steve Pribyl Steve Pribyl is offline
Default Re: Pro Tools First No Input
Success!!!
I was able to change the sub channels in the Audio Midi Setup to use the ART Pre instead of the the system mic and speakers and it seems to be working, even though the labels are wrong. I have input!
Thanks! You are brilliant
Steve
File Type: jpg Screen Shot 2021-02-10 at 6.35.10 PM.jpg (43.4 KB, 0 views)
Old 02-10-2021, 06:45 PM
Sub-devices, not sub-channels
Old 02-10-2021, 06:47 PM
You will want to check drift correction for both of the devices.
Old 02-11-2021, 05:38 AM
Bookerv12 Bookerv12 is offline
Your device should also be showing 2 outputs.
It did in your first set of pictures.
bookerv12
Old 03-06-2021, 05:52 PM
FYI, the majority of this problem was traced to a bad interface. The ART Pre Pro was giving me all sorts of problems and I didn't realize that was the source of the trouble. Replace it with a Scarlatt solved the input problems
  #16
Old 03-25-2021, 08:02 AM
guitarkevin69's Avatar
guitarkevin69 guitarkevin69 is offline
I'm having a similar issue with a brand new M-Audio M-Track Solo I just got. I've followed this thread (thank you all). Prior to following this thread I was stuck at not being able to record-enable my track, but I followed the steps in this thread to set the hardware and playback engine to the Pro Tools Aggregate I/O and set the subdevices to the USB AUDIO CODEC input and output with drift correction enabled on both. Although I can now get to Track > I/O > Interface. I only have 2 options (In1 and In2). I tried both and am not getting a signal in the track when I record-enable. I'm plugged into Line 2 on the interface (Hi-Z setting). And I do see the signal light on the interface light up when I play. I can also hear myself through the headphones, plugged into the interface.
I am a total newbie here, so if anyone can help, that would be awesome. I hope it isn't hardware related like with the OP.
guitarkevin69
Pro Tools | First
M-Audio M-Track Solo (USB)
Experience Level - newbie
HP Elitebook 840 G5
Windows 10 build 1909
RAM - 8GB
CPU - Intel Core i5-8250U @ 1.60GHz
SSD - 128GB Internal
Input setting help (hardware input 1 wants to be Protools input 5) TheBaron Pro Tools 2020 3 07-14-2020 09:14 AM
Input in pro tools amscheme macOS 2 12-16-2018 11:16 PM
no input signal in pro tools 10 HD mbmusic Pro Tools TDM Systems (Mac) 6 08-09-2017 04:33 PM
Getting mic input into Pro tools Marco73 Getting Started 2 03-19-2017 01:46 PM
No input from 003 rack to Pro Tools 9 saxygreeneyes macOS 2 11-03-2011 08:43 AM
