Master Fader Clipping
Whats up guys,
I was wondering if anyone has a situation where the master fader shows the red clipping indicator without noticible distortion in the audio. I am using instrument tracks and the only track that has imput is the one I happen to be working on at any point and time. As i said the signal sounds fine and none of the individual tracks are clipping but the master fader clips on almost every beat. I have on many occasions browsed through the DUC and I can remember reading that it's never a good idea to turn down the master fader. There are no affects on any of the tracks and the only plugins are Virtual guitar 2, expand and hybrid. All other sounds are comming from my keyboard which is a triton studio. All faders are at 0db. So why the master fader clip? |
Re: Master Fader Clipping
Ah, Grasshopper.
The sum is always louder than all its parts combined. Go forth and mix with your faders lower, and enlightenment you will find. (Your mastering engineer with thank you too )
http://www.oneearthproductions.net |
many thanks to you oh wise master of the pro audio wonderland!!
*sniff* .. that was beautiful. |
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
sorry to butt in but is there anywhere on the duc or the digidesign web site that explains the master fader in more detail?
So the information in Chapter 25 (specifically, page 480 for the 7.x version) of the Reference Guide (available from the help menu within the program) doesn't quite do it for you? I find it very informative and detailed.
Yes, two tracks peaking at 0dB simultaneously renders +3dB, four makes +6dB, eight makes 9dB, etc, but note that the mix engine is 32-bit, so there is 24dB of overhead prior to the master fader adjustment. You could literally have 256 tracks all peaking at 0dB simultaneously with the master fader to -24dB and nothing gets clipped. (8 bits = 8 x 3dB = 24dB, 2^8 = 256)
You can also go over 0dB in tracks using plugins without clipping from the mix engine, and I'm not concerned if some tracks light up the clip light, but I don't make a practice of saturating the mix engine. Ironically, there is nothing to "gain". (badum-tshhh!) |
Master Fader clipping | Von_Dingle | Pro Tools 9 | 4 | 10-24-2011 11:47 AM |
Master Fader is Clipping, what now? | Peulock | Pro Tools TDM Systems (Mac) | 21 | 03-08-2009 07:06 AM |
Fixing Clipping in Master in Master Fader | pakobo7 | Pro Tools M-Powered (Win) | 10 | 09-16-2006 10:53 AM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
Master fader clipping? | brasssail | Pro Tools TDM Systems (Mac) | 4 | 03-15-2000 09:40 AM |
