#31
Re: HD Native Personal Mini Review
Hey Tom,
Now that you have and are enjoying your native system, will you be content enough with it that you can let go of HEAT and perhaps any other TDM-only plugs? I ask because I'm debating a native HD system vs TDM because I'm thinking I may want HEAT, Phoenix and some of the Eventide stuff...
"I'm not really HoboSoul™, but I play him at the DUC..." Mac Pro 12Core 3.46G (5.1) | 64G Ram OSX 10.11.6 | PTHDN/OMNI/Apogee Duet(non Avid) 10.3.6 / 11.3.1 Need mixes, mastering, guitar, keyboard or bass parts added to your tracks? Need custom songs/music written and produced for special occasions? Check out The Soundz Shop. Great work by pros with multi-platinum experience at excellent prices... |
#32
There are no TDM only plugs that I miss except HEAT ( I was using the demo) and Phoenix. They are killer indeed. That said, I think you will see HEAT in RTAS, don't know about Phoenix, eventually. I use the Oxford Limiter (in ENHANCE ONLY MODE) which does a lot of that character thing, so losing those plugs is not a deal breaker. The amount of money saved, the tracks gained....man this system is rockin'! Very impressed. And it's supposed to be even better at 96, I am at 44.1. Tom |
#33
"I've mixed huge sessions on an HD1. I haven't had much trouble being efficient with my track layout."
I doubt you'll get more than smiles from most people when you use the words "mix," "huge sessions," and "HD 1" all in one sentence, especially if you are trying to use HEAT! "I've tried 128 and indeed I do feel it. Not with instruments with a slow attack but with drums or quick keyboard parts it's an issue. The delay kills the vibe." I play piano and program drum parts daily, but that has nothing to do with HD1 vs Native....??? Pick a buffer you like and go, either system. Bottom line..this HD Native System kicks an HD1 system around quite severely and is easily the equal of an HD2, which I've also worked on extensively. Peace T |
#34
It sounds like Native is a success for you. That's good. Unfortunately, try as you may to convince me otherwise, I can't adjust to the compromises of Native, and, fortunately, I don't need to.
#35
I'm hoping -- and you guys can please confirm this for me... that with the new HD|Native card -- there is NO limit on VOICES except the limit DIGI puts on for max track count.. Is that correct? So with PTHD9 I 'should' be able to get 192 voices at 96K??? Please -- say YES! If so -- this is a VERY strong reason for HD1 owners to consider getting out of their HD1 rigs and moving to HD|Native -- as the VOICE limit is the main downside of HD1. And of course you'd have to live without TDM only plugins -- which will be hard for me - giving up my REVIBE, MASTERX3 and REVERB ONE and DRAWMER. But I can find other flavors I like if I could only get MORE voices. Now the last question would be -- is the HD aspect of the HD|Native card the SAME 2 mix bus and summing as HD Accel? That's the main thing I'm worried about. Not to start a long debate -- but it's the TDM 2mix buss that keeps me in HD. I'm convinced it's the best sounding out there. SO if I can get rid of VOICE limits but still have the 2mix bus SOUND of HD -- I'm in!
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
#36
But some of your argument sounds a little like the guy who buys a $90,000 Steinway -and in comparison tests in the studio against his $15,000 Kawai -- being 'unwilling' to do double blind tests to see which one sounds better -- because the guy who spends $90K on a Steinway HAS to 'believe' it would sound better -- even it if doesn't.. I've been in that chair too.. and quite often a $30K Kawai sounds WAAAAY better than the Steinway in the double blind tests. I really have to take exception to your statement that you've done HUGE mixes on HD1 and never had voice counts issues. The math just doesn't add up, my esteemed colleague. If you have 2-3 plugs per track (a minimum for most of us)-- you WILL, ALWAYS, run out of voices eventually at 48K on a 'HUGE' mix (50+ tracks) -- and certainly you will at 96K - which is all I cut at these days. Then there's your latency argument. Remember you're probably remembering ProTools LE at 128. HD|Native is a different animal that you haven't personally tried yet. And please -- in Low Latency monitoring mode in even LE -- if you do a phase cancel test on an input session tracking at 128 versus 64 -- not I 'nor' you - are 'good enough' musicians () to make the case that there's a 'feel' difference between the two when using LowLatency Monitoring in LE. Even playing percussion. Sorry -- there just isn't. And I have to believe it's even better in HD|Native. I was with you about the 'not wanting any trade offs' issues going from HD to Native - but then when you cited your 'examples' of the alleged trade offs -- you lost me. Again -- we're talking HD1 systems here in the 'argument'. I've been in HD 1 for 'several years now' - work in it all day, every day - and voice counts, at the mixing level -- is a 'seriously' buzz killing issue. If HD|Native gets rid of that AND can promise me the HD '2 mix buss' then I may be in. But if the 2mix bus in HD is a funtion of TDM -- then all bets may be off. I NEED the 2mix buss sound of my HD1 system. "IT'S" the reason I left the Native world behind. It had nothing to do with TDM plugins. In fact I'm one of those 'weirdos' that like the RTAS instantiations of 95% of the plugins OVER the TDM versions. Though as I've said - the TDM Only reverbs, ReVibe and ReverbOne are truly amazing 'go-to' plugins for me. They would be HARD to replace.
#37
NewDestinyX
just playing devil's advocate here. I'm wondering if the 2mixBus from HD that you're hearing, have been accustomed to, and left LE for - is more the interfaces themselves then the actual Float Point v.s. Fixed Bit math of the 2 Mix engines ? Many in here claim that bounces in the 2 environments (HD & LE) completely phase Cancel / Null and that the "End math" results in the exact same. I'd LIKE to see some controlled tests on that, from Avid themselves, or someone Actually neutral in here. but it seems no one is neutral - the DUC has become littered with the HD v.s LE debate - And i really DO hope PT9 closes that gap a bit, for nothing else, but to bring the DUC back to a place, I feel it "Once was" where we all talked about music production, troubleshooting, tips etc... I wandered OT there on a rant (Like I used to) for a sec :) Back to the original point - I wonder if listening to your mix, through a native card (Which does NOT have the TDM Fixed Bit Mix math), and your 192, or an Omni - v.s. "What you were forced to listen to your LE mixes through" (002, 003 etc...) if THAT wasn't the difference. I'm posing a question, and genuinely curious.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
#38
But let's not reopen that old can of worms. Suffice it to say -- you're right that the D/A you're working with MATTERS. And what I 'hear' when mixing 'affects' my mix decisions. So I 'could be' open to an argument that says -- I need TDM because I need a 192 I/O to make my best mix decisions. So -- then that would lead me to the fact that an HD|Native system CAN hook up to a 192I/O - right? So there's a "LOT" of me that's leaning to the HD|Native system. But what does the HD part mean? Just that it can hook up to the Digi HD hardware machines? And again I ask -- is the 2mix buss handled by TDM chips in an HD TDM system?
#39
I'd like to know if with HD/Native and a first generation Mac Pro Quad 2.66 XEON, say on a session that I usually open up on HD2...say 50 tracks, 10 auxes & few plugs on each...can I get through it without the "Lose RTAS bump Buffer" thing?
#40
I have the Mac Pro 2.66 1st Gen plus the HD/Native and at the moment I'm mixing with over 70 tracks, few auxes, a ton of plug-ins and the CPU meter reads a high 68% but the buffer error have been very few. Two or three at most and coming from the lowest Mac Pro series, this ain't bad. From what I've been hearing, stick a new Westmere to the game and we'll certainly be starting a new chapter. I believe Tom said it best when saying the HD/Native is very much an HD 2 system. Yes, been there, done that. I'm running the 96io but also hoping in getting the OMNI and UAD card. Hey, add a 6 core Westmere to the mix and this could be sweet! Cheers! |
HD Native / Omni...... a positive review | Arkman66 | Pro Tools HDX & HD Native Systems (Mac) | 4 | 06-19-2012 01:33 PM |
HD Omni Mini-Review | TimNielsen | Pro Tools TDM Systems (Mac) | 86 | 03-03-2012 06:51 AM |
SLATE DIGITAL plugins mini-review | BradLyons | General Discussion | 11 | 04-02-2010 07:05 PM |
Amplitube 2 mini-review/impressions | davetron5000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-23-2006 09:05 AM |
OT: RNP mini review | Chris Coleman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-11-2003 10:51 PM |
