error -6031
i'm getting a pretty typical under-run error (-6031). messing with all playback settings has nothing to do with it. i can't even playback one track with no effects. i used to have an mbox which would only work when plugged into the USB 2 port nearest my power port. now i'm trying to set up an mbox 2 which connects to my powerbook through a firewire connection. could this have anything to do with it? can anyone think of anything else? i've updated to leopard 10.5 and have tons of RAM.
thanks for any thoughts. i'm frustrated. chris |
Re: error -6031
We're going to need a bit more info to be able to help you troubleshoot - the Help Us Help You thread has details about what we need to know.
You may also want to visit the General Troubleshooting thread (below my signature), as it has many suggestions for optimizations that may fix your problem. |
Re: error -6031
The MBox2 is USB, not firewire----are you referring to the MBox2 Pro? If so, that IS firewire. I noticed you said you upgraded to OSX10.5, but you actually need 10.5.3 or higher, right now I think we're at 10.5.7 which is compatible.
Run out of CPU error 6031 | Roland Clarke | Pro Tools TDM Systems (Win) | 0 | 01-22-2013 08:41 AM |
Error -6031 | fisaac | Pro Tools TDM Systems (Win) | 19 | 04-01-2010 11:54 AM |
Possible fix for DAE error -6031 | dvine | Pro Tools TDM Systems (Mac) | 0 | 06-09-2003 07:50 PM |
Digi 001 - Logic Audio - (Error -6031) and the error (-10011) - Direct I/O | booyaaslam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-04-2002 01:55 AM |
DAE error -6031 | binet | Pro Tools TDM Systems (Mac) | 1 | 07-09-2000 06:59 PM |
