Old 07-09-2000, 05:38 PM
binet binet is offline
Default DAE error -6031
Since I got my new Seagate Medalist AV ST39140N Protools doesn't want to read more than 10 tracks without stopping and writing "Unknow driver software or automation dat is using too much CPU Bandwith. Please ensure that compatible disk drivers are installed. If so try thinning automation data (-6031) " .Where is this bad driver ? Is this a problem with HFS format ? Help !
Old 07-09-2000, 06:59 PM
DigiTechSupt's Avatar
Default Re: DAE error -6031
binet
Without knowing any your system information
It is hard to tell whats going on. Check
that the drive is initialized with the ATTO
drivers or FWB. Make sure the synch rate is set to (20) 10 on the SCSI host card. This is
where to start. Post all system information
if you have tried all of these suggestions
or dont know how to change the synch rate.
On adaptec it is done with the power domain software ver 5x, ATTO ver 2.3.2
MJ
Digidesign Tech Support
[This message has been edited by TechSupt (edited July 09, 2000).]
Avid Audio Tech Support
Support FAQ
Run out of CPU error 6031 Roland Clarke Pro Tools TDM Systems (Win) 0 01-22-2013 08:41 AM
Error -6031 fisaac Pro Tools TDM Systems (Win) 19 04-01-2010 11:54 AM
error -6031 cwarrenk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-09-2009 10:39 AM
Possible fix for DAE error -6031 dvine Pro Tools TDM Systems (Mac) 0 06-09-2003 07:50 PM
Digi 001 - Logic Audio - (Error -6031) and the error (-10011) - Direct I/O booyaaslam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-04-2002 01:55 AM
