Pro Tools First No Input
I can't seem to get Pro Tools First to recognize an input signal. I tried reinstalling Pro Tools First, and restarting with "N" held down, but nothing I do will allow me to select an input.
Pro Tools First apparently created an "Aggregate I/O", but I can't get that to work either. I'm using an ART USBDualPre interface with a mic and headphones plugged in. I also tried disconnecting that and using the system mic and speakers. Please see attached screenshots Your help would be greatly appreciated! Macbook Pro Catalina OS 10.15.7 Steve |
Re: Pro Tools First No Input
I'm not seeing your interface listed in the playback engine list. (I think)
bookerv12 |
It shows up as USB Audio Codec in the list.
Hey,
Did you chose that as your playback engine? If so, open Protools, open I/O setup page, if it is shown as the playback engine, hit Default in each I/O page.
bookerv12 |
In your input for the track, chose interface and which of the 2 inputs you want to use.
bookerv12 |
I tried selecting the interface (USB Audio Codec) as the playback engine. The tracks still show "no input". Pro Tools First does not have an I/O Setup Page. Steve |
Go below "No Input" to "Interface?
Inputs listed?
bookerv12 |
From looking at your pictures,
Go to playback engine, change it to your interface. Tell it to accept your interface as the two inputs and outputs. Tell it to accept your interface as clock. Select using your interface's inputs and outputs under subdevices. Then, go to a tracks input and select Interface (Input 1/2)
bookerv12 |
Tell it to accept your interface as clock. Select using your interface's inputs and outputs under subdevices. I'm not sure how to follow these commands Steve |
Input setting help (hardware input 1 wants to be Protools input 5) | TheBaron | Pro Tools 2020 | 3 | 07-14-2020 09:14 AM |
Input in pro tools | amscheme | macOS | 2 | 12-16-2018 11:16 PM |
no input signal in pro tools 10 HD | mbmusic | Pro Tools TDM Systems (Mac) | 6 | 08-09-2017 04:33 PM |
Getting mic input into Pro tools | Marco73 | Getting Started | 2 | 03-19-2017 01:46 PM |
No input from 003 rack to Pro Tools 9 | saxygreeneyes | macOS | 2 | 11-03-2011 08:43 AM |
