Installer can't "write the receipt"????
-Mac book pro 2.4 GHz Intel Core 2 Duo
Mac OSX 10.5.4 4 GB 667 MHz DDR2 SDRAM, bus speed 800 MHz external HD LACIE 500 GB FireWire 400 MBOX2 with PTLE 7.4.2 Please help me, I was re-installing PTLE on custom mode after getting an error during the previous installation (something wrong with a "/"....) so I first re-installed only the "application files" and went fine..but when I tried to install "digirack plug-ins" and "freebombfactory plug-ins" the instalation fails saying "THE INSTALLER COULD NOT WRITE THE RECEIPT FOR THE PLUG-INS"....Core audio was ok, so I opened PT and entered my authorization but I don't have the plug-ins!!!!!! I've followed the troubleshooting infos I've found here step by step (settings,screen,disabled ports,airport.....everything) and now??? Please answer ASAP, I had 10 days of madness with this MBOX2 |
Re: Installer can't "write the receipt"????
Ok, try this - go to MacHD>Library>Application Support and trash the Digidesign folder, then do a clean uninstall/reinstall of Pro Tools.
Hopefully that will clear up the problem. |
"clean" means custom or guided???
"can't write the receipt" pt.2.....
"Ok, try this - go to MacHD>Library>Application Support and trash the Digidesign folder, then do a clean uninstall/reinstall of Pro Tools."
I've done, still doing the same thing......I'm goin' mad on this ....doesn't work so I DON'T WORK. |
Did you do that? Have you tried installing from a different Admin account? |
"Unable to write receipt for plug in updates" | Freddyroc747 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-29-2012 06:20 PM |
Pro Tools 9.0 "Updater" or "Full Installer"? | jacknprewitt | Pro Tools 9 | 7 | 12-24-2010 08:47 AM |
The installer could not write the receipt for "plug-in updates" | Dedelman2005 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-22-2009 08:53 AM |
help!? "the installer could not write the receipt for "plug-in updates"?? | onosai | Pro Tools TDM Systems (Mac) | 2 | 10-15-2009 08:32 PM |
Installation Problems, "could not write the receipt" | thegordian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-22-2009 04:49 AM |
