Pro Tools and FL studio
I'm wondering if anyone is having any luck running FL studio as an instrument in Pro Tools, cuz I'm not. I set up FL on a stereo instrument track, no other tracks or Plugins in Pro Tools. I set up one FPC channel in FL with a simple drum loop. I can't get it to playback for more than 30 seconds. I get errors telling me I'm running out of CPU. I have a 3.5 ghz quad core processor. Watching the cpu meters when it's actually playing it's at about 10% but there is some crazy spiking going on. I also haven't been able to save a session and exit it without the whole computer freezing and having to restart. I'd like to know if there's a way to make this work. Both programs run fine on my machine independently. Are there versions that are compatible? This is what I've got now. FL studio 9.1, Pro Tools LE 8.0.4cs2, mbox (3rd gen), Windows 7 Ultimate 64 bit, 3.5 Ghz AMD Phenom Quad core processor, 8 gigs of ram.
Thanks |
Re: Pro Tools and FL studio
Is FL Studio 9.1 Windows 7 64-bit compatible?
Aaron Mulqueen - 001 HD Native |
yes and like I said it runs great on this machine on it's own. I've made a little progress, I got it to playback without any trouble, but the saving and loading of projects is still eluding me.
There could be a TON of things causing this problem, including, but not limited to your computer having an incompatibility for running Pro Tools. When most people hear this, they usually claim "B.S. that couldn't be happening to my machine it's powerful and brand new" but its a known fact; Pro Tools is very picky about windows computer hardware and needs certain basic requirements to be met to run properly.
If you want us to check yours, you can read the "Help us help you" sticky and post the specs of your computer. Here are some basics that might help you:
There are a few others, but that's a start. <opinion warning> Also, FL Studio has always been sketchy for me when running rewired to any program. I own it (it was cheap and I needed it for a client session), but I really think there are better programs/options. YMMV
Thanks, I wouldn't be surprised if something was incompatible. I've had a pretty difficult time getting Pro Tools to be stable on this machine, I think I've got it goin pretty good now. I didn't know about disabling wireless cards, I do have one, I'll try that next. I typically don't run beta versions, but I'll give that a try too. I got into FL a long time ago for cheap, when it was still called fruityloops, I like what it has grown into, so it'd be great if I could get it goin with pro tools. I'm new to the forum and forums in general, I don't know what "sticky" is. I did go to my profile and add my motherboard and processor, I'll add more later when I have more time. Thanks again
It's definitely not a bad program for the price, and I do like certain things about it, but it has always had problems integrating with Pro Tools. I've owned it since version 4.5.
I never said FL was the best, just that I like it...
Here's the Sandra report. SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : Scarecrow-PC User : Scarecrow Processor Model : AMD Phenom(tm) II X4 970 Processor Speed : 3.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 4 threads sharing Computer Mainboard : Asus M4A89GTD-PRO/USB3 BIOS : AMI 1456 05/04/2010 Bus(es) : ISA X-Bus PCI PCIe USB FireWire/1394 Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : No Total Memory : 7.75GB DIMM DDR3 Chipset Model : AMD RS780 Host Bridge Alternate Front Side Bus Speed : 2x 2GHz (4GHz) Total Memory : 128MB Shared Memory : 368MB Channels : 2 Memory Bus Speed : 2x 723MHz (1.45GHz) Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 2GHz (4GHz) Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 579MHz (1.16GHz) Memory Module(s) Memory Module : SanMax F3-10666CL7-4GBECO 4GB DIMM PC4200U Memory Module : SanMax F3-10666CL7-4GBECO 4GB DIMM PC4200U Video System Video Adapter : ATI Radeon HD 4290 (40 SM4.1 700MHz, 384MB 2x667MHz, Integrated Graphics) Graphics Processor STREAM Processor : ATI Radeon HD 4290 (40SP 2C 700MHz, 368MB 2x667MHz, Integrated Graphics) Storage Devices WDC WD6402AAEX-00Z3A0 (640.1GB, SATA600, 3.5", 7200rpm, NCQ) : 596GB (C:) WDC WD2000BB-00GUC0 (200GB, ATA, 3.5", 7200rpm, 2MB Cache) : 186GB (D:) ASUS DRW-24B1ST (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) ASUS DRW-24B1ST (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) ASUS DRW-24B1ST (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices System Reserved : 100MB (NTFS) Hard Disk (D:) : 182GB (NTFS) @ WDC WD2000BB-00GUC0 (200GB, ATA, 3.5", 7200rpm, 2MB Cache) Hard Disk (C:) : 596GB (NTFS) @ WDC WD6402AAEX-00Z3A0 (640.1GB, SATA600, 3.5", 7200rpm, NCQ) Optical Drive (E:) : N/A @ ASUS DRW-24B1ST (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (F:) : N/A @ ASUS DRW-24B1ST (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (G:) : N/A @ ASUS DRW-24B1ST (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ATI (AMD) IXP SB600 SMBUS Controller LPC Hub Controller 2 : ATI (AMD) SB700 LPC host controller LPC Legacy Controller 1 : T2 87-21 Audio Device : ASUS IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : ATI (AMD) RS880 Audio Device [Radeon HD 4200] Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Disk Controller : ATI (AMD) SB700 SATA Controller [IDE mode] Disk Controller : ATI (AMD) SB700 IDE Disk Controller : ASUS JMB361 AHCI/IDE USB Controller 1 : ATI (AMD) SB700 USB OHCI0 Controller USB Controller 2 : ATI (AMD) SB700 USB EHCI Controller USB Controller 3 : ATI (AMD) SB700 USB OHCI0 Controller USB Controller 4 : ATI (AMD) SB700 USB EHCI Controller USB Controller 5 : ATI (AMD) SB700 USB OHCI2 Controller USB Controller 6 : ATI (AMD) SB700 USB OHCI0 Controller USB Controller 7 : ATI (AMD) SB700 USB EHCI Controller USB Controller 8 : ASUS uPD720200 USB 3.0 Controller FireWire/1394 Controller 1 : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller Wireless Adapter 1 : Rosewill RNX-N180PCe Wireless LAN 802.11n PCI-E NIC (802.11g (ERP), 48Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.7 Performance Enhancing Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
If it works for you, it works for you. That's all that matters.
I've seen a few people have problems with the "RS" series of chipsets. Quote:
The USB 3 stuff is still kind of up-in-the-air compatibility wise. Definitely would need to be disabled when using Pro Tools.
I host an open mic every week, I record it and make cds for everyone that comes, I got tired of burning them one at a time, that's why I have 3 optical drives.
I turned the wireles adapter on and off and it doesn't seem to have any effect at all on pro tools or FL... At this point I'm guessing that my problems are because of usb 3.0. If I leave the mbox plugged into the same usb port that was used during installation everything's fine. If I try to move it to another port it's pretty much over, the only way I've been able to get pro tools to see the mbox after that is to reinstall. When I can afford to switch to pro tools 9 I think that will help, my most common problem is pro tools cannot find hardware, so it won't open. But I'm not having any problems running pro tools on it's own at this point, occasionally I get dae error -6006, then I restart and it's fine. The only trouble I'm having is trying to use FL as an instrument. I did actually one time save and reload a session with FL as an instrument, but only once. The 9.7 download links were down lastnight so I haven't been able to try that yet... Integrated graphics are going to have to do for now, cuz that's all I got... |
I'm noticing that I only get that DAE error -6006 after putting the computer to sleep. Thanks for your help.
Pro Tools/FL Studio HELP!!!!!!!!!!!! | CWHITEPROD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-23-2011 09:40 AM |
Recording in real studio, mixing at home w/ Pro Tools, mastering at real studio | scummyjob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-17-2010 03:02 AM |
Logic Studio taking files to pro tools studio. | smoochdaddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-30-2009 10:55 AM |
Transfering Pro Tools sessions from studio to studio!!!! | clinka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-10-2008 01:19 AM |
FL STUDIO IN PRO TOOLS LE | ANTDEM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-18-2005 03:45 AM |
