Old 12-24-2001, 02:10 PM
Bastiaan Bastiaan is offline
Default Re: ProTools with Roland XP30 Synth
hi, i dont know that much of midi either, but here's what i should do
Open a new midi-track, set it to record and start playing on your midi-stuff.
fiddling around like this made it possible for me to record all the settings i made to a midi-equiped outboard efect...
Otherwise take a look in the manual....
Bastiaan
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 12-24-2001, 02:20 PM
SixChurchStreet SixChurchStreet is offline
I did just that. Made a new track, all the connections are ok, it's record enabled, and i get nothing. I looked in the reference guide, but i didn't see anything about initially setting everything up. I started this thread in the MIDI section of the DUC too. Any help would be greatly appreciated, i want to see this thing work.
- kip
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM El Capitan | 2011 MacBook Pro 2.0GHz 4-Core i7 8GB RAM El Capitan | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2018 | Studio One 3.5
Old 12-24-2001, 02:41 PM
English Jim English Jim is offline
Make sure the send channel on the synth and the recieve/record channel in PT are the same.
...don't you boys know any nice songs?
Old 12-24-2001, 02:47 PM
Allen Hallada Allen Hallada is offline
Kip,
We use a Roland Piano 3000S. We also use a Roland MT32 sound module that is a stand alone product that is hooked to the piano. I just unhooked the sound module and hooked up the piano to Digi so that I could simulate your setup.
Roland midi out to Digi midi in
Digi midi out to Roland midi in
Created Midi track
Set input of track to Digi001 / channel all
Set output of track to Digi001/ channel 1
Record enabled track and recorded a sample
Worked great. Played back through the piano speakers.
Recheck your cable input/outputs
Recheck your input/output on each track
Recheck your sounds/multimedia in control panel and make sure you have Digi as your midi device.
Good luck.
Allen
[img]images/icons/smile.gif[/img]
Old 12-24-2001, 02:48 PM
I've got the send and recieve all set to the same. channel 1 all around the board, and still nothing. is there anything i need to configure, add, setup, or should i be able to just plug in and go, as long as my connections are ok, and the channels are the same? this is puzzling.
- kip
Old 12-24-2001, 02:50 PM
Just need to make sure your inputs on the track are set correctly. As I said above, I just used Digi001/Channel all.
Keep us informed.
Allen [img]images/icons/smile.gif[/img]
Old 12-24-2001, 02:58 PM
This is killin me.
In my multimedia devices, the digi001 is my only available midi device, and yup, it's selected of course.
i created a midi track. input is ALL, and output is channel 1.
midi out on digi is hooked to midi in on my roland. and vice versa.
i have created an aux track to hear the playback from the l/r outs of the roland, that's of course working fine.
the midi cables are both good, cause i use the same ones with a Motor Mix from time to time, and never had a problem with that.
sounds like the problem could be in the setup somewhere of this xp-30?? the menus are pretty cryptic, but everything vital to MIDI looks ok. what could i be missing?
- kip
Old 12-24-2001, 03:11 PM
thanks everyone. well, i got it going. i did a factory reset on my xp-30 and it corrected whatever was wrong in the settings. i'm sure i'll have additional questions. like, how do i get the midi click to play? thanks again everyone.
- kip
Old 12-24-2001, 03:15 PM
Congrats Kip,
Happy recording.
Old 12-25-2001, 01:49 AM
Default ProTools with Roland XP30 Synth
Howdy folks...
I am very very new to MIDI. So new I know little or nothing about it. I am trying to get my Roland XP-30 synth hooked up to my Digi001. What do I need to do to make this thing work? start from the top, cause so far i've gotten nowhere. does anyone else have a similar setup? i am in desperate need of assistance with this one.
- kip
GR-50 roland guit synth gargoyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-20-2003 06:12 AM
Roland V-Synth Vegadark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-23-2003 11:52 AM
How do I get my Roland xp30 to show up on midi inputs surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-31-2002 01:55 AM
Roland XP30 & PTle christoph3r MIDI 1 02-24-2001 11:21 PM
Seeking Roland XP30 or JV2080 OMS names templates proteus Pro Tools TDM Systems (Mac) 3 09-22-2000 01:26 AM
