Old 06-24-2004, 05:34 AM
GW GW is offline
Default Waves and Bombfacory plugins in correct folder?
How do I get the Waves plugins into the correct folder in PTLE 6.4? What Waves version - 4.0.5...or? Wave-shell version - 4.0...or? Anything else?
How do I manually move plugins that are in the wrong folder (like Fairchild 670 in the EQ folder)?
Digi002, PTLE 6.4
Factory bundle
Waves Platinum
Bombfactory Fairchild 660/670 TDM, Pultec EQ TDM, Tel-Ray TDM, Classic compressors (Value Ed.), Clipremover and Tuner...
Antares Autotune and Tube
Timeworks RTAS
Sony Inflator TDM ver. + Dynamics RTAS
URS n12 EQ
Firum, Equim EQ:s
VST2RTAS wrapper
PSP Vintage Warmer, EQ
Choir Clone
Reason 2.5 Full Ed.
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Old 06-24-2004, 07:49 AM
Bazzle Bazzle is offline
Default Re: Waves plugins in correct folder?
I just open up the folders in question and drag them from one to the other.
Bazzle
Old 06-24-2004, 12:34 PM
GW GW is offline
You mean - you opened a sesseion, tried to insert a plugin but insted just dragged it to another folder choice? I can't do that, I had tried that already.
Any more suggestions or clarifications on the suggestion above?
Old 06-24-2004, 12:47 PM
Sorry I thought you meant they were installed on your SYSTEM in the wrong folder.If you are talking about Plugin Catagory Menu it can't be done.You can change it back to the way it was before the upgrade. By deselecting Sort Plugins by Catagory in your preferences.
Bazzle
Old 06-24-2004, 03:45 PM
GW GW is offline
Thanks, I will try that. But what makes a compressor like the Bf Fairchild 670 end up among the EQ:s?
Old 06-24-2004, 04:02 PM
There has been lots of discussion on the forum about this.I guess it will be up to the manufacturers to add the proper codes to their plugins.It is really quite farcical at the moment.
Bazzle
Old 06-24-2004, 04:24 PM
You have an old version.. update your plug-ins and they'll be in the correct location. For Waves you'll have to wait for the next version.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 06-25-2004, 05:13 AM
bladesg bladesg is offline
I'm used to this little quirk already. [bleep] better than it was before, Plugs covering the whole screen.
Old 06-26-2004, 06:00 AM
GW GW is offline
What are the latest Bombfactory versions and where do I find them? (I can only find upgrades for the ones in the HD pack).
Links?
Old 06-26-2004, 10:29 AM
Links?
Go to the main www.digidesign.com web site, click on Developers then click on Plug-in Info... you can follow each plug-in and download the latest version(s).. or go to the downloads section of this site.. but I've found the route I've described above has some newer versions that aren't in the downloads section.
Rail
Platinum Samples
Removed waves plugins, now getting prompt saying "locate" folder remusjacobs macOS 1 07-25-2012 07:15 PM
Select Waves 6.1.1 Plugins Folder sleazedc Pro Tools M-Powered (Mac) 5 07-05-2012 10:10 PM
select Waves 6.06 plugins folder in 8.0.1 a7bull 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-17-2009 11:47 PM
Waves plugins folder issue yop22 Pro Tools TDM Systems (Mac) 0 09-01-2009 09:43 AM
Waves 6.0.6 won't let me find plugins folder abbyin3d Pro Tools TDM Systems (Mac) 9 05-20-2009 09:32 AM
