Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 07-16-2010, 07:07 PM
xBlackPearlx xBlackPearlx is offline
Default *FIX* unable to locate m-audio hardware
After many months of searching on the internet and trying my best to make this program work. I finally found that the error is real simple to fix and its been right infront of me all allong.
Remember that audio adapter that came with your protools and keyboard? That wasnt given to us for no reason. You need to plug in your headphones into that adapter to make it work. I didn't think I would need it since I have a speaker system, but it is required. Everytime time I saw "unable to locate m-audio hardware" I kept thinking my midi is not being recognized, but all allong it was because the midi was working with Fruity Loops and other stuff. I kept thinking something from pro tools is not recognizing the midi keyboard.
Well I hope this helps everyone. Use that adapter that says M-Audio on it and the program should work flawlessly.
'Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o roland342 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 09:01 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on ytass Pro Tools M-Powered (Win) 4 11-25-2009 12:49 PM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
unable to locate M-Audio hardware. Make sure your hardware is connected and turned on joskraus Pro Tools M-Powered (Win) 13 05-13-2009 09:05 AM
