Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 01-23-2012, 08:59 AM
plastic_soul plastic_soul is offline
Default tech help needed, no sound
Hi there everyone,
i have just installed pro tools SE 8.0.3 on my iMac i got the software with the M-audio fast track, the problem is i can not hear any sound
i have the same setup using garageband and the sound works fine
now the levels and everything in pro tools seems to be picking up sound as i can see the levels go up or down when using the mic or my guitar but i cannot hear anything when i splay or speak or even playback, can't hear any loops or beats
now the strange thing is before opening a session i can play the demo's from the splash screen and can hear them fine
any help would be greatly appreciated its really frustrating !
cheers
Dell
Old 01-24-2012, 11:30 PM
RegenerationMix RegenerationMix is offline
Default Re: tech help needed, no sound
do you have a master fader in your mix and are the outputs of it assigned to main outs 1-2 ?
Do you have your I/O setup and routed correctly? it sounds like you are getting signal in to pro tools correctly, but not routing it out correctly from pro tools.
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
Old 01-25-2012, 02:22 AM
yeah everything is set correctly, i dont have any headphones at the mo to plug into my m-audio interface im guessing i will get sound from there but i need to hear sound through my stereo also
its very strange that when i play a sound on the demo screen i can hear but not on any tracks or loops
Old 03-16-2012, 04:36 AM
still need some help, would be really appreciated, even if my stereo is not hooked up i dont get any loops or instrument sounds coming out of the mac built in speakers, i am still able to preview demo tracks on the menu screen though, please please help
cheers
iMac OS X Lion , M-Audio fast track, Pro Tools SE 8.0.3
Old 06-07-2012, 12:56 AM
bblack1023 bblack1023 is offline
This may be a little advanced for you but give this a try. Create a Pro Tools Aggregate in your Audio Devices screen of your preferences. You can then select all of your in and out including you built in inputs and outputs. In pro tools pick that aggregate and you should be able to play the sound through the built in outputs. Let me know if this helps!!!
-Brandon
Tech wizard needed! RunwayAD Pro Tools TDM Systems (Mac) 0 06-07-2010 08:30 AM
tech opinion needed tomdolan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-21-2009 12:38 PM
OT: analog console tech needed in LA Mark Wheaton Pro Tools TDM Systems (Mac) 0 04-20-2004 07:14 PM
Tech Spprt Answer Needed: SSC/001 CCash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-12-2002 12:41 AM
Tech needed in Los Angeles larry saldano General Discussion 0 06-10-2000 07:05 AM
