Blocking the "P" and "F" sounds in vocal tracks.
I can't find the plug in, but I KNOW I had it before, it helped the "f" and the "p" sounds from being so powerful or help block them in the vocal tracks. Does anyone know what plug-in I'm talking about plz let me know! its driving me crazy!
Re: Blocking the "P" and "F" sounds in vocal tracks.
A de-esser and a pop filter might get you on your way?
de-esser ! haha thankyou!
You might also try backing the singer off the mic a bit more and/or double up the windscreen(popper stopper) or even angle the mic slightly so the singer is singing by the mic instead of straight at it. Sometimes the De-esser kills too much so I end up using AudioSuite EQ and treat the region directly. If you highlight the "P" sound and hit preview on the EQ plugin, you can take an EQ bad and set it very narrow and boost to +9 and sweep it around. When you find the frequency that jumps out much louder, cut that frequency and hit process.
An old engineer's trick (and fyi I am an OLD engineer) is to clamp a pencil about 4 - 6inches in front of the mic. The pencil takes the 'p' sounds and 's
' sound and dissipates it (what you hear of course is the wind hitting the capsule). Also, this will not change the sound, like a windscreen might. |
If you've already tracked the vocals here's a trick for you. Duplicate the vocal track, invert the phase of it, trim it so that this track has just the offending sounds (the p's, f's, etc.) then mix it (lightly) with the original. The flipped phased of the duplicated track will lower the volume of the offending sounds.
"Sometimes having limits keeps you sane"- Albee1952 |
And when all else fails, you can always go in and manually draw the offending sound down a few dB in volume automation.
Worship Leader * Producer * Guitar Man Intel i7 3930k CPU, Gigabyte GA-X79-UD3 MB, G.Skill 16GB (DDR3 1600) RAM, WD Caviar Black 750GB HD x4 Neve 5043 Comp * Manley Dual Mic Pre * Apogee Rosetta 200 Eleven Rack (live rig and studio rig!!) Win7 * 003R * PT 11
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" | xfarre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-22-2011 07:37 AM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
minimising mic "sss" and "tttt" sounds in singing | Matt Darcy | General Discussion | 7 | 09-12-2008 06:47 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
