couple of quick questions!
I've a couple of things bugging me in Pro Tools 11.0.3 on mac. 1. Occasionally, when I add a plugin, all audio gets a horrible digital crushed sound to it. When I change the bugger size (up or down, doesn't matter), the sound goes away. It doesn't seem to be an overload issue, just an odd bug. 2. I'm using a wireless keyboard and a magic trackpad, since I installed them I can't seem to use the "change grid amount" shortcut (cmd alt & - or +). this is something I use constantly so it's really annoying me. the manual says that the shortcut is only possible with wired keyboards but does anyone have a workaround? thanks Steve
Prism Orpheus, PT 11, Mac 2x2.26GHz QuadCore Intel Xeon, 16g ram Outboard - ADesign, Chandler, RetroDesign, Roland. |
Re: couple of quick questions!
1. Do you have Ignore errors during playback/record checked in the Playback engine? I had to uncheck it for that issue to disappear.
2. Works fine here, but I use a wired keyboard. The shortcut for the grid value is Ctrl+Alt+plus/minus. Cmd+Alt+plus/minus changes the nudge value.
Much appreciated. Now if I could figure out the lack of a shortcut thing I'll be pleased :)
Since you are on a MAC have you tried adding that keyboard shortcut in your keyboard manager (system preferences>keyboard)... add that shortcut for Pro Tools and see if it works, if not make your own and tell it to control the "Change Grid Amount"
http://lifehacker.com/5720087/how-to...ut-in-mac-os-x
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
couple of quick questions? PLEAAASSEE | tempest1226 | General Discussion | 4 | 08-17-2009 11:00 AM |
Couple Quick Questions | BillDog793 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-17-2007 03:40 PM |
Couple quick questions: | TimNielsen | ProControl, Control|24, Command|8 | 2 | 06-10-2005 10:10 AM |
Couple Quick Questions About LE | mman00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-22-2003 08:58 AM |
Couple of quick questions.. | craiz730 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-14-2003 03:06 AM |
