Old 03-21-2020, 09:37 PM
Oscar.Rivas Oscar.Rivas is offline
Default Maschine 2.1 failing to load in Pro Tools 2019.12 after update
So I just updated all of my Native Instruments plugins and now Maschine 2.1, Komplete Kontrol, and Reaktor 6 are unable to load. The error reads "The following plug-ins failed to load because they are not valid 64 bit AAX plug-ins:". I have Komplete 12 and it seems that all other instruments are ok. My setup is Pro Tools 2019.12 on 2019 16" MacBook Pro, i9 2.4 ghz, 32 GB Ram. I attempted to reinstall Maschine, I updated Mac OS so now I'm on 10.15.3. Everything ran fine before I updated NI. Please help! Maschine is crucial to my production workflow in Pro Tools. Thanks!
Edit: here's a picture of the error.
Edit #2: not sure why picture is upside down...took and added multiple, still upside down
Old 03-22-2020, 10:03 AM
DetroitT's Avatar
DetroitT DetroitT is online now
Default Re: Maschine 2.1 failing to load in Pro Tools 2019.12 after update
Security in sys prefs
Trash prefs Ni and pts
Will it open standalone?
Old 03-22-2020, 03:41 PM
Default Solved!!!
Solved!!
So I found a post by a NI support on a forum that read:
"You might want to give this a try for Maschine 2.8.4 :
- navigate to : Macintosh HD > Library > Application Support > Avid > Audio > Plug-Ins
- delete the Maschine 2.aaxplugin
- launch Pro Tools / close Pro Tools
- Reinstall the Maschine application with Native access.
- Start Pro Tools again"
I tried it and it worked! I'm surprised more people haven't had this issue. One thing I noticed when deleting the plug-in file from the folder, was that the "created" and "modified" dates were from 2018, even though I had just updated them the day before. Weird. Anyway, it worked. Hopefully this helps anyone else having or that will have this issue in the future.
Old 04-28-2020, 01:56 PM
shisko shisko is offline
Thank you very much, Oscar. I had the same trouble with Reaktor 6 and your fix worked like a charm.
Old 04-28-2020, 09:36 PM
Awesome! Glad it worked. The stress level instantly increases when something that normally works, doesn’t. Good thing there are forums like these still around!
AES Update for Pro Tools 2019 krabbencutter Pro Tools 2019 34 10-23-2019 05:26 PM
Does Pro Tools 2018 update to 2019? Lotus Studio Licensing & Accounts 6 06-16-2019 02:04 PM
Pro Tools 2018.1 - Video Engine failing to load (Windows 10) Lana Banana Pro Tools 2018 2 02-08-2018 08:26 AM
Plug-ins (Boom/Xpand/Structure) failing to load on startup Lozlizor Windows 1 05-07-2016 06:26 PM
PT failing to load activated plugins MStephens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-23-2007 05:40 PM
