Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 07-15-2013, 05:46 PM
jt1432 jt1432 is offline
Default MBOX 2 MINI Showing constant loud noise in meter but I can't hear it!
If anyone can help me it would be greatly appreciated. I have dredged the internet as well as these forums for a solution and have not even found a thread that closely resembles my problem.
First off I'm "currently" running Reaper X64 in Windows 7 and before I was running Pro Tools 8.04 le. About a month ago everything was working fine in Pro Tools until one day I had to restart my computer. The next session I tried to record on when I enabled the track the meter showed a constant noise all the way to the yellow and does not fluctuate. It is almost as if there was a high pitch wine at a constant db level or something on that track. I disconnected everything from the mbox except the usb and it still showed the noise. So I thought it must have been the preferences or the driver needed to be reinstalled. So I trashed those and reinstalled the drivers and nothing. Then I noticed that if I tried to record out of input 2 everything is fine. The meter only shows up when I record enable any track's source that is set for input 1. The weird thing is that the noise can not be heard. I don't hear any interference, high pitch wine, no static or even white noise. Even when I record a guitar on the track the guitar track can be heard but whatever the meter is recognizing is inaudible. This is when I switched from Pro Tools to Reaper was because I thought it might have been Pro Tools and the Mbox is demonstrating the same problem. I have tried changing what usb port I was using and I tried reinstalling the drivers, but all with no luck. I'm pretty computer savvy and do know how to search the forums but I just didn't quite know how to label what problem I have been experiencing so I apologize if this problem has it's own thread because I could not find one.
Thanks
~Justin
Old 07-15-2013, 06:30 PM
Default Re: MBOX 2 MINI Showing constant loud noise in meter but I can't hear it!
Here is a picture of what I am experiencing. Take note that this is exactly what I see with nothing connected when I'm recording from both inputs 1 and 2 of my mbox 2 mini. As you can see my meters show some kind of noise when recording out of input 1 and that meter level never fluctuates it stays constant. And you can hear nothing not even through head phones.
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini Bigpit Windows 1 09-09-2013 09:26 AM
Mbox mini 3 constant beep noise during playback MR290378 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-09-2011 01:49 AM
Mbox 2: record enable constant meter overload?? msnorthc@comcast.net 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-21-2010 11:40 AM
incoming audio to loud to hear tracks in headphones mBOX rost 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-27-2008 01:14 PM
Mbox mini loud noise and strangeness voiceoverguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2007 09:13 PM
