mono / stereo question
Hi Avid DUC,
I was a logic pro user ,only just moved to protools 8 HD I have some question in regards the import section How come protools imports all tracks into stereo? For example if i import a bass file which is mono, it creates a track pan hard left & right. why is this so? Under create new tracks u have the option of mono tracks. Why doesn't it just creates a mono track for mono files? In logic, it does it automatically. You also have the option at the bottom of the channel strip to switch from stereo -mono or the other way around. Can this be done in protool?? I have just imported around 15 mono tracks into protools. They are all converted to L & R. Can i change back the channels to mono? Any help and advise would be much appreciated Thank you for your time and advise |
Re: mono / stereo question
protools does not duplicate mono files into stereo tracks on import in the case that they are mono.
i've imported lots of tracks from various sources, they come in mono if they are mono. i imported tracks from a band's garage band demo session, garage band can't export mono files so it exports each track to stereo. i had to import to the region list and copy the files onto mono tracks. i'm not familiar with logic pro, are you sure the file isn't being exported as stereo? |
import mono files all the time into mono tracks. Logic exports mono files as stereo! because logic is stupid Chris
I am sorry for such a newbie question :) But it always triggers me to ask the following:
Should I record Those in Mono or Stereo: Drums: Pads: Strings: Bass: Leads: Vocals: ..... |
Drums: Each mic should be mono, unless you are using a polar 8 pattern to save mics in between toms, which would then in turn end up in mono once you split the two channels of the polar 8
Pads: Stereo Strings: Mono unless you are doing an ensemble, then you'll need multiple mics and mic placing. You should be placing a few mics in the live room anyways in different spots to catch the natural reverb if it's good. If it's not one up close and then use a good reverb. Bass: Mono Leads: I'm assuming lead guitar here? Mono unless the effect is bouncing in stereo, which you'll then need to mic each amps in mono Vocals: Mono unless you are doing a take of a duo or quartet, again using a polar mic for duo, it's going to be mono anyways once split up. Hope that helps |
Million Thanks .. :) It's just I don't do Live Recordings ... I Just use Virtual Instruments ... so I guess for Drums it would be better to go Stereo as well as pads ... and the rest is mono ..
1. kick 2. snare 3. rack tom 4. floor tom 5. overhead right 6. overhead left From that, you create the stereo image. 1. kick - centered 2. snare - slight pan right 3. rack tom - slight pan left 4. floor tom - slightly more pan left 5. oh right - hard right 6. oh left - hard left
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Funny . . . all of my bidirectional microphones only have one output!
Yeah you need to use stereo figure 8 that you patched through a stereo to mono decoupler. I don't know if there's any plug ins that do that, I used to use a outboard box patched back to two inputs of the mixer to do it. Then reversed the polarity of the signal of one of the channels. This way you'd get tom 1 on a channel and tome 2 on the second. If you didn't reversed the polarity you would get phase cancellation.
A question about mono/stereo plug ins on mono tracks. | rockguitarist1255 | Pro Tools 10 | 2 | 12-24-2011 07:33 PM |
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-14-2010 09:01 AM |
mono/stereo question | studiokeyz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-13-2008 01:25 PM |
Stereo and Mono question | Daubian | Post - Surround - Video | 2 | 03-15-2007 09:08 PM |
Stereo/mono question | totemspock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-25-2005 08:28 PM |
