  #461
Old 12-11-2007, 06:48 PM
sunburst79 sunburst79 is offline
Default Re: Best Core 2 Specs
Doh! I missed the 4-pin power connector. I'll be hooking that up tonight and hopefully moving on to configuring the BIOS. Thanks for the suggestion!
-John
That happens a lot more than you might think! Also be aware that the newer P35 Asus boards have a part of the POST process where the board seems to power down like theres a problem and its shutting down-after it pauses about 2 seconds the POST process resumes and its off to the races.
Mykhal and I are working on a Step by Step guide to building a Quad and should have something up on the front pages relatively soon.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
  #462
Old 12-11-2007, 06:53 PM
EGS's Avatar
EGS EGS is offline
That would be very helpful. Please also list the date on the parts listing (oh wait, maybe the date's already there). Thanx, guys!!!
Desktop: Win 7 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / PT 9 / Focusrite LS56
Laptop: Win 7 / HP ProBook 4730s / i7-2630 / 8GB / PT 9 / U-PHORIA UMC1820
Info/Services link
  #463
Old 12-11-2007, 07:12 PM
With the exception of the video card going out of stock the last time I checked the rest of the parts were still current. It's not like its a carton of milk or anything
It does get updated more than the "Best Desktops" thread
Scott
Core 2 Specs Page
  #464
Old 12-11-2007, 11:37 PM
mykhal c's Avatar
mykhal c mykhal c is offline
Copy the ROM file to a USB flash drive then restart or reset the PC.
When PC reboots hit ALT+F2 whilst the PC is still POSTing and then you should enter the EZ Flash utility. Direct it to the appropriate ROM on the flash drive and when prompted flash the new revision.
blade, i'm tryin' to make sure that the ram is runnin' at 1066 and i'm gettin' confusin' reports from SANDRA and CPU-Z. i have it set in the bios as 1067 with timings of 5-5-5-15. where can i verify that this is actually what's runnin'??? i'm seein' DDR 6400 in SANDRA and seein' 4 columns in CPU-Z with different settings under the SPD tab. the memory tab confuses me even more. anyway, i know you'll set me str8 and maybe it is still bios related since i have not updated it yet and i do have the first bios from the mobo. so maybe i'm not gettin' accurate readings well point me in the right direction bro...thanks
sunburst, i know you're still on the road otherwise i'd be buggin' you too
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #465
Old 12-11-2007, 11:55 PM
email me a screen shot of the SPD tab..
Its fine!
CPUZ is not always 100% accurate in what its reading hence the DDR3 6400 and. But the timing figures are reported correctly.
You know its right in BIOS
Scott
Core 2 Specs Page
  #466
Old 12-12-2007, 12:24 AM
mykhal c's Avatar
Its fine!
it's on the way
  #467
Old 12-12-2007, 03:13 PM
versatyle versatyle is offline
-John
Yes that would be great! Thanks.
  #468
Old 12-12-2007, 10:18 PM
bladesg bladesg is offline
The figure you see in the memory tab are also more than likely correct. Remember (I think I posted something about this somehwere) that with DDR memory we have to x 2. So if the memory tab in cpuz says 533 or thereabouts then you are actually running the memory at 1066. You should also see the divider or what ASUS call strap in the BIOS and then the timings.
What you're seeing in the SPD tab are timings based on the manufacturers recommendations that are programmed into an eeprom on the RAM PCB. If you're seeing more than one set of timings then chances are that you have yourself some memory with EPP. These are performance profiles that can be dialed up in the BIOS.... however these are of no use to us Intel users because AFAIK there isn't an intel chipset motherboard that can take advantage of EPP.
Anyhow.... best of luck with it
  #469
Old 12-13-2007, 02:56 AM
Kirby B. Kirby B. is offline
Default Re: Best Core 2 Series Desktops-Results and Specs
Sunburst79, Is this the ram you are recommending to replace the one I proposed in my post?
Corsair, XMS, 1024Mb, PC6400 DDR2, 800Mhz, 5-5-5-12, alu heat spreader
I guess if I wanted 4gb, I would buy 4, correct? I really don't understand many of these numbers Thanks
Hi, Please tell me if this isn't the right place to post.
I will upgrade my trusty AMD 64 system for the computer I plan to build listed (so I can comfortably use 7.4), but I want to know what you think. I will have my local computer guru help me, but he doesn't know anything about PT.
Gigabyte Case Poseidon
Asus P5K Deluxe Wifi-AP, s775, P35
INTEL Core 2 Quad Q6600, 2.4 Ghz
Corsair, 2048Mb TwinX DDR2 1066 Kit Dominator, 2x1Gb, PC8500, 5-5-5-15, EPP, alu heat spreader
(should I get 2 or wait if I need the second?)
Graphics card: Asus, Geforce 7300GT Silencer, 256Mb DDR2, DVI,
Hard drives not determined, but I see that there might be a problem with the Samsung HD that I have (Sata) so will probably use WD. Seagates hard to find in Switzerland.
Thanks in advance for a look over. I may be totally off base about the MB/ CPU thing..
Mobos good, CPU is good. The video card should be good. Not to much memory and no fan As I recall RyanK is running a 7300.
At one point there where some problems with the Dominator so I advise sticking with the the regular XMS series where its available and cheaper. 2GBs if fine to start with.
I would stick with a the Seagates or the WD's at this point. Too many posts have been popping up across the Forum with Samsung stuff listed. I would rather people stick with whats working especially since the Quad and the P35 boards are not offcially approved By Digi yet (hopefully they will just move on to X38 and Penryn and save the next big round of questions )
CORE 2 System Specs
Intel Quad
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
  #470
Old 12-13-2007, 09:52 AM
mykhal c's Avatar
hey blade, thanks again. i'm slowly makin' progress well i updated the bios to the 0603 bios and that took care of the error i was seein' when bootin'. the update also allowed for accurate numbers to be reported in CPU-Z. so i think part of my confusion was the fact that the bios was outdated in regards to the newer cpus and memory. in fact the PATRIOT memory was listed to run at timings of 5-5-5-9 which i set in the bios and it's workin' as designed and now CPU-Z is reportin' it exactly as i have it set in the bios the only thing that seems a bit odd is now the temp on the cpu reads higher. before the update i was gettin' temps of 39c for cpu and 32c mobo from PC PROBE. now i'm gettin' 46c cpu and 32c mobo. i'm usin' the stock cpu heatsink and fan so maybe i will find i need to upgrade but i'll roll with this for now
thanks again for the bios instructions. worked like a charm!!!
i7 Builds - Specs and Results mykhal c Windows 6781 Today 07:11 AM
Intel Quad Core vs. i-series solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-23-2010 05:16 AM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 02:24 AM
are these specs ok? (low budget 2 core) korkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2008 02:44 AM
8 Core Mac Pro, Leopard and Windows results pasanta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2008 06:51 PM
