Vienna key & iLok on hub?
I know it's generally not a good thing to run an iLok on a hub, or is that just on an unpowered USB hub? The reason I ask is I'm considering getting VE Pro 5 and that uses it's own dongle variant. However I've run out of USB ports on my iMac and would have to go to a hub. Said hub would more likely than not have both dongles on it. Would be a powered hub.
I figured I'd ask here because there's a bunch here who run VE Pro alongside PT and have to deal with this situation. Am I looking at problems or what? This is on ML on a 27" iMac 3.4 GHz i7 setup with 11R as audio interface and PT 10.3.2. |
Re: Vienna key & iLok on hub?
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Maybe I'm just lucky, but I have had 2 iloks and a vienna key hanging from a hub that's on a 15' extension cable for well over a year with no issues. There is nothing else plugged into the hub of course.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Are your powered by an external supply or the USB port? I can go either way on that, although a port powered hub would be great. |
I've done both without issues. The keyboard is powered only via USB, but before that they were always in a powered hub. Never once had an issue, iLok1 and iLok2.
Thanks - much appreciated. I've run hubs before but not in something mission critical like recording; previous daws and vi's didn't require dongles.
I've had the same good experience as Dism, I've run Iloks both off the wired keyboard ports and off hubs with no problems.
I use VePro 5 and Pro tools, both dongles on a Powered hub and never had a problem.
I have my iLok, my Steinberg/Arturia key, and my Novation controller in a powered USB hub. No issues whatsoever.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Vienna Ensemble Pro | Belegur | Virtual Instruments | 23 | 03-31-2015 01:07 PM |
with PT 11... no more Vienna Ensemble Pro? | Anibal | Pro Tools 11 | 14 | 11-06-2013 11:04 AM |
FS: Vienna Ensemble Pro 5 | whittybeats | Buy & Sell | 2 | 04-22-2013 01:48 PM |
PT10 Win7 - Plugins folder? Vienna? iLok? | smc917 | Windows | 1 | 04-18-2012 06:52 AM |
Vienna MIR and PT | Dfx | Virtual Instruments | 0 | 01-08-2011 02:33 PM |
