Old 02-12-2012, 07:11 PM
Aikoaiko Aikoaiko is offline
Default Cant record enable more than one track at a time
I made a new session template with an updated I/O list, etc.... and now when I record enable a 2nd track, the first is disabled. I can no longer enable two tracks at the same time. I went back to other sessions and can still enable two at at time and I cant see what I did wrong on the new template. Any ideas?
Thanks!
PT8 / MBox2 mini
Old 02-12-2012, 11:15 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Cant record enable more than one track at a time
Have you ever had Pro Tools working properly over a long period of time on your current system?
Post a Sandra Report;
Use SiSoftware's Sandra Lite application to generate a full system profile:
www.sisoftware.co.uk
Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 02-13-2012, 10:07 AM
What kind of tracks are these? On my system, if I want to put more than 1 instrument track into record-ready, I hold the ALT key and click on one, and that makes all the instrument tracks go red.
Old 02-13-2012, 11:46 AM
I'm enabling a mic and guitar line in. But I also use up to 6 at a time when I render my drums to an audio file (to save CPU). I enable one track, then when I click to enable the 2nd track, it turns off the first track that I enabled. Crazy. I have gone back to older sessions and multi tracks work at the same time just fine. So I think I must have done something in preferences, or setup, etc.... on my new template.
If I have to, I will utilize an old session to make a new template, but I would like to understand what caused this to occur. And keep all of the work I did on the new
template.
Thanks
Old 02-13-2012, 12:54 PM
Never seen that here with audio tracks. Maybe try trashing prefs? That's step #1 for any "odd" behavior with Pro Tools.
Old 02-19-2012, 01:35 PM
I found it: Setup/Preferences/Operation Tab/Record - Latch Record Enable was unchecked.
thx
Old 02-19-2012, 02:55 PM
The Weed's Avatar
The Weed The Weed is offline
Or, if the Preference is unchecked, just Shift + Click other record buttons when one is lit.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
can't record enable a track macfreak86 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2011 05:11 PM
When I enable a track to record and then hit 'play' the track will remain silent Rainerbird Pro Tools M-Powered (Win) 2 08-07-2009 09:41 PM
Track Record Enable KC mattrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-26-2009 06:58 AM
Record enable more than 1 track at a time... broken81 Tips & Tricks 9 08-03-2008 10:58 AM
Why can I only record enable/play one midi track at a time? Martin Dubka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2008 01:24 PM
