Re: CPU usage is holding off USB audio
Anyone still looking at this? I would appreciate it.
I've got this problem to, plus my mbox stops sending audio from PT to the mains out on the mbox when this occurs (and sometimes randomly it seems). Would like to get an endorsment from Digi before I start messing with Virtual Memory - although in Classic days this was always recommended..........
Cheers Johan |
I too have a Mac Book Pro with a USB error -9136. my system coughs up the error during playback. I seem to be having some other strangeness in my transport window because when I set the record button then hit play to start recording the recording imediately stops thereafter. I have not had much free time lately so my attempts to troubleshoot these issues have been fruitless. I hope this conversation will continue. Justin I would like to hear about your recent discoveries concerning your issue. Any other advice would be great, but if fear my confidence in computing tasks is limited. thanks in advance
Joe Taylor |
Back in the days of digi001's and Mac OS 8.6, turning Virtual Memory off was a must.
I can completely understand not wanting to delve into this, especially if Digidesign has another solution. Though, consider the quandry / solution ratio. |
Hi all, in regards to MBOX USB draining CPU on Macs errors.
THERE IS NO SOLUTION I have been reading FAQ's from 2004 - OCT 2006 and there are hundreds of people all with the same problem. G3's, G4's, G5's - OS9x - OSX. PT 5.1 - PT 7.0 All Digigdesign say is to reflash your Mbox with firmware 2.0, which most MBOX's are 2.0 anyway, and then take some plugins off. When your running a G5 and you can't run 2 plugins you know something is wrong. Digidesign have been silent on this issue. Sorry guys. Don't do USB and Digidesign. It's PCI or the new Firewire. I've spoke to the Tech support and there is NO SOLUTION. If your not using a laptop, sell your MBOX and get a 001 on ebay. You'll be able to run 95% more plugins.
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
#16
#17
I'm going to try a PCMCIA USB card here in a couple days and I'll let you know how it goes. If it works out, then I'll probably send my powerbook back for repair and tell them something is wrong with the USB bus. I do get noise through the mBox in one of them, so that might be enough for them to repair it.
Is anyone from digi still looking at this? Can you confirm that there is no fix for it for some macs? |
#18
However, I also have a Powerbook (last-generation model) and am having the described disk access problem (but with an 002R). It's not so much when I'm demanding a lot of audio data to be streamed either, it's generally more when I'm simply demanding more from the processor (in fact, that's when this Powerbook shows how really old and out-dated its processor is). onlyone-jc. |
#19
Have any of you actually tried it? Give it a shot, you might be pleased.
You can turn it back on by uncommenting the line and rebooting, this is not permanent in the least. |
#20
I would like to add that I've been a PT user for about 6 years.
I started with the 001 on a pc and for years, I've had no problems. This year, I switched to a G5 and upgraded to the 002R. Then everything started going wrong. I was constantly getting error messages with the operating system held off for too long. I called tech support so many times and in the end, they told me they've done all they can. I then sent the 002R back to Digi to have it checked. It came back with no problems according to Digi. It went to a point where nothing could be done anymore so I sold it and I am now using the mbox. But now with the mbox, I'm getting the cpu/usb errors. Its happening more and more. I really like Pro Tools, but if its not gonna work, I have no choice to look elsewhere. My job depends on the daw I use.
PPC G5 Dual 2.0, 8.5G Ram PT 8 cs2 OSX 10.5.8 MBP Core 2 Duo 2.16, 2G Ram PT 8 cs2 OSX 10.5.8 Mbox 2 Pro, Mini, Micro |
CPU usage is holding off USB audio | stefunktrumpet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 01-04-2011 08:22 PM |
CPU Usage Holding off USB audio help | Nathan W. | Pro Tools TDM Systems (Mac) | 3 | 07-08-2010 03:21 PM |
"CPU usage is holding off USB audio ... " | MrBrown | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 11-12-2005 02:54 PM |
cpu usage is holding off usb audio | J-Mac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-29-2005 09:36 PM |
CPU usage is holding off USB audio | Whitecastle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-26-2003 09:34 AM |
