Old 06-07-2005, 07:49 PM
Sty1es Sty1es is offline
Default Crashing constantly in 6.9.....Help!
Running ProTools TDM 6.9 on an OSX10.3.9 loaded 1.8 G5 w/1GB Ram, with HD2 Accel hardware and Apogee converters. The software hangs almost every take, making it really hard to get anything accomplished. The WAV files are usually there afterwards in the backup sessions. I've tried putting the sessions on 3 different hard drives with little to no avail.
Help me!
Old 06-07-2005, 08:53 PM
Monte McGuire Monte McGuire is offline
Default Re: Crashing constantly in 6.9.....Help!
I understand that 10.3.9 is not supported. 10.3.8 however is...
Hope that helps...
-monte-
Old 06-07-2005, 09:14 PM
Thanks man, the weird thing is it's been working with other sessions but it isn't working right now...
Old 06-08-2005, 01:58 AM
crizdee's Avatar
crizdee crizdee is offline
Hello,
If it is only this session that is crashing! then open a new session and use import session data! to import all the parts in from the session that is crashing, this way you will be running with a new session and this will clarify if the session was corrupted etc.
If this does not fix, then give a more detailed discription of what is happening, what setup you are using and are you getting crash logs? if you are getting crash logs then you can look at them and see which thread has caused the quit and this could give you some indication of what is causing the crashing.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-08-2005, 09:47 AM
DigiTechSupt's Avatar
You might also want to try all the 'General Troubleshooting' steps, which may help.
Avid Audio Tech Support
Support FAQ
PT 10.3.7 crashing CONSTANTLY! LSD-Studio macOS 6 11-30-2013 11:56 AM
Pro Tools 10 constantly crashing Scott Swallow Pro Tools 10 5 10-15-2012 09:29 AM
LE 7.4 crashing constantly, especially during bounce clingerpratt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-21-2011 08:19 AM
LE 6.4 constantly crashing, please help! granduch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-05-2006 06:08 PM
HELP ME! 6.0 Crashing Constantly tactics008 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-28-2003 12:00 AM
