Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 07-04-2020, 03:50 AM
avidenthusiast avidenthusiast is offline
Default Long overdue move from PT8LE to 2020
Hi
I'm still using PT8LE, and am struggling to figure out what I need to buy to move to the latest PT whilst still having the ability to run old RTAS sessions.
From what I can tell, this means I need to be able to run PT10 as well as latest PT on my Windows computer. Can this problem be solved?
Thanks for any suggestions
Old 07-04-2020, 04:45 AM
Sardi Sardi is online now
Default Re: Long overdue move from PT8LE to 2020
PT10 is the last version to run RTAS plugins.
But, if the plugins you use are available as AAX (most probably are) then your session should in theory open fine in the latest version of PT.
Do some homework and see if they are. If so, no need to bother with PT10. You can’t buy that version anyway unless you go second hand, so you might as well try and go the whole hog.
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
Much overdue PT upgrade advice needed! axismatt Pro Tools TDM Systems (Mac) 1 02-06-2012 05:03 AM
We Are WAY Overdue for Patch +/- Key Commands relaxo Virtual Instruments 3 02-02-2012 05:14 PM
Let sleeping G4's lye? Some overdue questions. ajazzie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-02-2003 10:16 PM
ProControl scrub Trim?? Long overdue, any news? Jules ProControl, Control|24, Command|8 1 04-16-2001 06:53 PM
