Old 09-05-2002, 09:55 AM
niki111 niki111 is offline
Default 2 track editing
I use protools for 2 track editing and dance compilations with 18 or so tracks crosfaded. If I use M-box can I get the same quality as my tdm system? I assume since its only spidif in I have to use the inport audio from movie comand if its a cd and if its a dat will the spidif sound as good as the AES digital on the mox plus? thx for all you help
Old 09-05-2002, 03:17 PM
Default Re: 2 track editing
bump
Old 09-05-2002, 03:30 PM
fire2k2 fire2k2 is offline
To tell you the truth, I can't tell the difference between my digital signal going through AES or S/Pdif. I guess there may be some advantage of AES because it is considered the pro standard. All of the pro gear has AES. But I doubt you will suffer any signal loss using S/Pdif.
L-Fire
EMO
Old 09-05-2002, 09:15 PM
where02190 where02190 is offline
M-box has 2 analog and 2 digital inputs, and uses the same software as the 001, which is PTle. I believe the converters in the M-box ar ethe same as the 001, and do not compare to the TDM converters.
Old 09-05-2002, 09:16 PM
Originally posted by ixnys:
I know I can't compete with million dollar studios, but I want something for myself that still sounds somewhat commercial and I feel inspired working on.
<font size="2" face="Verdana, Arial">But since we are dealing with only digital signals, the converters don't come into play at all.
Old 09-05-2002, 09:48 PM
I'm not even gonna touch that one.
Old 09-06-2002, 09:55 AM
if i go in and out digital will there be any dif in quality between the m-box and mix plus?
Old 09-06-2002, 01:15 PM
Chompers Chompers is offline
No, there will be no difference.
Dont worry about all the TDM Voodoo.
You mixes will sound every bit as fat as the TDM counterpart.
Since what you are doing is all digital and uses very little processor power, you will be golden!
Old 09-06-2002, 02:21 PM
Avid's Avatar
Avid Avid is offline
Administrator
<font size="2" face="Verdana, Arial">Yes, from what you are describing. If you are going to be exchanging sessions with your MIX system you should be aware of this guideline:
http://answerbase.digidesign.com/detail.cfm?DID=5831
Excerpt:
...if you plan on exchanging sessions between Pro Tools LE and TDM systems, it can be prudent to attenuate the input level of a Plug-In like DigiRack EQ if you have applied a large amount of boost to a predominant frequency (like a big booming kick drum). This will avoid the possibility of clipping in the TDM version of the Plug-In, and you'll still get to take advantage of a "24-bit clean signal" when levels are set correctly.
Administrator
Old 09-06-2002, 04:10 PM
Admin- i wont be using plugins- very rarely- I concernened since the mix plus I use is aes digital and the m-box is spidif will recording digital in , editing ( stereo) and the recording digital out will it sound as good as using my mix plus aes digitals? also does m-box protools le have tab to transient? stereo tracks? thx:.. [img]images/icons/smile.gif[/img]
Multi-Track Editing EAPEntertainment CO Pro Tools 9 9 03-31-2011 03:23 PM
Editing onto a new track Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-09-2008 04:51 PM
Editing Track Sections kathedral 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-14-2007 10:48 AM
2 track editing 2nd room m-box? niki111 Pro Tools TDM Systems (Mac) 9 05-28-2002 07:56 AM
2-track editing/mastering chuckw Pro Tools TDM Systems (Mac) 10 03-22-2000 09:12 PM
