Controller, and Automation lanes.
Why is they're no show all in the controller lanes on the plugins.
Pro Tools HD 8 | HD 2 Accel | 192 I/O | MacPro Harpertown 2.8 | OSX 10.6.1 | Magma ExpressBox4 - 4 Slot PCI Express® Expansion System |
Re: Controller, and Automation lanes.
I don't know of other DAWs that do that either.
Why Not
I have no idea but it sounds like a job for Feature Wishlist.
you could easily fill the screen with a plug like Virus or even Sonox EQ+Filters
Ray Trujillo Freelance Audio Engineer |
Some times you jest need to see what you have done.
@Jim - I agree with you. Sort of show/hide all, show/hide all used/unused. Sounds good.
@Ray - I have no idea what you mean or how that relates. |
Cubase & Nuendo have a show all used automation lanes function. Very usefull!
Terrence... I was saying that some plugs have an enormous amount of automate-able controls. If you have plug in controls default to auto enabled on, you could easily fill up your whole edit window with the automation lanes of one plug. Just saying you could be in for quite a surprise when you show ALL automation lanes. If there is some selectivity, I could see where it might be useful. I use a control surface, so I usually don't need to see the automation unless I need to tweak it, and then it's just one parameter.
Propellerheads Record does this as well as Reason. It does help when you can see all the params worked on in the lane. They have it kinda like the playlist view in PT8. It would be a great new feature.
www.christurbiville.com |
Shortcut to toggle viewing automation lanes? | Farmer Dave | macOS | 5 | 04-07-2013 03:17 AM |
Loosing Controller Lanes in MIDI Editor | chuckgreenjr | macOS | 0 | 11-02-2012 03:42 PM |
Different controller lanes for each channel | Polarbear066 | Pro Tools 10 | 2 | 10-17-2012 03:32 AM |
How to Copy/Paste/Dup Automation lanes? - help! | superfiction | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-15-2010 01:27 PM |
Show Hide Automation Lanes - Shortcut ? | Tomy DeClerque | Pro Tools TDM Systems (Win) | 0 | 02-07-2009 04:06 AM |
