Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 10-29-2019, 07:39 AM
kaonashi kaonashi is offline
Default S6 MTM Memory Issue
Hello,
Been experiencing an issue with an S6 MTM running 18.3.0 firmware, having memory issues I've attached a photo of this.
This then crashes the MTM and is a full restart on the S6.
Running Pro Tools 2018.4, we've only come across this issue recently we have another room running an S6 and pro tools on the same firmware, never experienced this. This is a unit on Satellite with 2 pro tools rigs connected however, I'm thinking this is an issue with the S6 internally rather than anything to do with our pro tools rigs.
Has anyone seen this before or have any idea what might be causing it?
Thanks
Old 10-29-2019, 12:05 PM
creativecontrol's Avatar
Default Re: S6 MTM Memory Issue
Greetings,
We have seen this before sporadically. Have you first tried an uninstall and reinstall of the same software version as Admin on the Master Module? If that is unsuccessful we would recommend performing a new image on the master module. Instructions for this process can be found here:
http://avid.force.com/pkb/articles/e...ore&popup=true
Let us know if you have any questions.
best,
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Presumably a memory issue? jimdpie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-15-2011 07:29 AM
PT 8 and 9 Memory leak? and Waves issue thierryd Post - Surround - Video 3 11-23-2010 10:16 AM
Memory Issue TLarvenz Pro Tools TDM Systems (Mac) 22 04-27-2009 08:28 AM
System memory issue ... OS X SPC Pro Tools TDM Systems (Mac) 1 06-07-2003 03:34 PM
Minimum memory issue clutch Pro Tools TDM Systems (Mac) 1 12-04-2002 12:12 AM
