Old 01-18-2009, 06:25 AM
GS-DK GS-DK is offline
Default Elastic Pitch trouble and double menu
Solved: Erased the Database - and now it works:
I feel very stupid - I can't get Elastic Pitch to work. Everything else works, but when I use the "pitch shift" nothing happens. What could be wrong.
Another problem (or bug) - all items are doubled in the Elastic Audio section.
Looks like this:
Polyphonic
Rhytmic
Monophonic
Varispeed
Polyphonic
Rhytmic
Monophonic
Varispeed
Hope you are able to help - thanks
Old 01-18-2009, 01:54 PM
EvilElfBoy EvilElfBoy is offline
Default Re: Elastic Pitch trouble and double menu
Just as a side note, Elastic pitch only works for polyphonic and rhythmic as far as I know.
AKA - EvilElfHobo
Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4
Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified.
Multi-Platinum Pro Tools Videos
Old 01-19-2009, 04:22 AM
Peter Duemmler Peter Duemmler is offline
That sounds like you have two Elastic Audio plug-ins in your plug-ins folder...?
(an older version was namend FELA.dpm AFAIR)
Peter
http://www.merlinsound.de
Old 01-26-2009, 06:09 PM
galtesler galtesler is offline
GS-DK - I'm experiencing the same problem with pitch shifting.
How do I erase the Database?
Thanks!
G
Old 01-26-2009, 07:55 PM
This is the best tool
http://www.jcdeshaies.com/
Old 02-17-2009, 03:24 AM
MoreDSP MoreDSP is offline
I'm having the same problem. Which "Database" file did you delete? I've tried using the ProTools Pref Helper, but no luck.
Old 02-17-2009, 06:06 AM
Use the program in my link - and erase all of them. It helped me....
Old 02-17-2009, 08:52 AM
KingFish KingFish is offline
Just a friendly warning, that there is a confirmed Bug in PT 8 with elastic audio once you get it working - if you "Select Unused regions" in your session, and Clear them... it'll select EA Pitched regions right off your playlists and remove them from the session as VERIFIED IN THIS THREAD
Until there is a fix (Likely cs2) make SURE you commit or render, all elastic Pitch manipulated regions, before you save, close, or clean your sessions.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 02-17-2009, 05:44 PM
Turns out I had a plugin wrapped for Novation automapping. I actually had thought of that, and made sure the Time Shift plugin was not wrapped. Didn't realize there was an "Elastic Audio" plugin too. Doh! By this time I had erased Databases, Volumes, Prefs, and then reinstalled PT8. Nothing worked until I unwrapped the Elastic Audio plugin. Another warning is don't wrap Ivory either, it will crash PT8.
Help, Double speed WITH pitch change? brizpaul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-28-2011 08:05 PM
Pitch Shift VS. Elastic Pitch StinkyStan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-24-2009 09:15 AM
Elastic Time is EXCELLENT.. how about Elastic Pitch.. bobo mark Pro Tools TDM Systems (Mac) 9 08-29-2008 10:41 AM
my audiosuite waves plugins show up double in the pull down menu peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-31-2002 12:56 AM
Tracks Playing back at double speed/pitch Louie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-14-2001 03:38 PM
