Old 09-22-2006, 04:53 AM
odeu87 odeu87 is offline
Default double clicking zoom tool
had a problem with 7.1 tdm system of not be able to double click zoom tool and have the waveform fill screen . it actually got smaller about an inch in waveform view. I was importing session files and each time that i imported a track that i had setup for talkback this problem occurred. i could make a new track with no problem or import all tracks except the talkback and everything worked . I then noticed that after recording a track with the levels setup for playback that when i would take the track out of record that the fader would snap to zero. checked that link record and play faders in the operations menu was checked and it was. trasheing all the preference files and database files didn't help still had same problem when importing session files with or without the talkback track. don't know if anyone else has had the to occur when importing session files but i finally trashed all my import session files and started from scratch with new session files everything seems to be working correctly now!
Old 09-24-2006, 01:57 PM
KingFish KingFish is offline
Default Re: double clicking zoom tool
There was an active region, Marker, or automation point "Far out" in the timeline, making the full session length, much longer then your song. - Find, and delete -
I could make a new track with no problem or import all tracks except the talkback and everything worked . I then noticed that after recording a track with the levels setup for playback that when i would take the track out of record that the fader would snap to zero. checked that link record and play faders in the operations menu was checked and it was. trasheing all the preference files and database files didn't help still had same problem when importing session files with or without the talkback track. don't know if anyone else has had the to occur when importing session files but i finally trashed all my import session files and started from scratch with new session files everything seems to be working correctly now!
Again this sounds like automation points in your session, which won't be read, while the track is armed.
You need to "Suspend All Automation" in pro tools, or, if this is "Phantom automation" that you don't want to use... delete it.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 09-25-2006, 01:47 PM
thanks i'll try deleting automation . got any idea why this happened? was working fine one day' next day was giving me the above problems
Old 09-25-2006, 01:59 PM
Przemek Przemek is offline
not be able to double click zoom tool and have the waveform fill screen . it actually got smaller about an inch in waveform view. I was importing session files...
It looks exactly like automation written in the end of the session - this is why you cannon zoom full by double-click - in fact you're zooming full, including invisible automation points. Check if during track import there was nothing like "session start earlier.." or sth like that, I don't remember exactly.
http://imaginatlh.com/91709
Importing Audio by double clicking a clip defaults to Add relder17 Pro Tools 10 7 09-08-2013 09:29 AM
Double clicking a region brings up the wrong midi editor cudithekid Pro Tools M-Powered (Win) 2 01-31-2012 05:17 PM
double-clicking grouped tracks removes group editingbehavior drguitar Pro Tools TDM Systems (Mac) 0 11-07-2007 10:53 AM
double clicking on region and weird things happen JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-30-2007 08:50 AM
Zoom tool on ProControl? michael c ProControl, Control|24, Command|8 1 11-18-2005 04:04 AM
