changes that make windows faster ?!
I´m looking for a sheet, that describes detailed, what to remove from windows 98se (eg in the registry ) to make my musiccomputer work more efficient and faster.
Has anyone an idea ? [img]images/icons/confused.gif[/img] |
Re: changes that make windows faster ?!
theres'lots of tweaks to do to optimize Windows for audio apps; here's a few.
-Disable Write Behind Caching: Control Panel>System>Performance>File System>Troubleshooting>Select last option. -Reduce Read Ahead Optimization: Control Panel>System>Performance>File System>Hard Disk> Decrease slider to the smallest setting. -Enable DMA for all IDE disks: Right click My Computer>Device Manager>XCilck on the + sign next to disk drives>Double click on each drive showed>Settings> check DMA (for CD Romtoo). -Turn "Auto Insert notification Off": same path as above, uncheck that option for ALL CD Roms and CDRWs. -IRQ settings: this is no easy issue, so if you encounter some IRQ conflicts try placing the 001 card in other PCI slots untill you find the one that doesn cause problems: it seems that 001 works well in slot 3 and IRQ forced to 9 in BIOS (in most computers). -Turn off any unwanted background running apps: Start>Run>type MSCONFIG> select startup>uncheck everithing except System Tray. -Graphic acceleration: right click on "My Computer">Properties>Performance>Graphics>decrease the slider to its smaller setting; this tweak doesn't have that much impact so you may wan't to let it where it is if you're using graphics apps together with audio. - The computer's role: Right click on My computer> properties> performance> file system> set computer role to "network server". There's others, but they're al little more complicated that these and involve a little more tweaking and PC knowledge to be written in two lines, if you need them email me I'll send a detailed article; the tweaks above should give you an increase in performance, but the results depend a lot on you system's configuration; also be sure to regularly defrag your drives, and use a dedicated on e for audio files only. Also check out prorec.com for interesting tips and tweaks on windowes machines. Good luck L.G. [img]images/icons/smile.gif[/img] |
Windows 8 PT 10 conflict. Trying to make it work. | martyredwhitmans | Windows | 6 | 02-13-2013 05:24 PM |
Can you make protools load faster? | jack2006 | Pro Tools M-Powered (Win) | 4 | 06-22-2006 07:27 AM |
Windows XP 64 Bit version....Faster for PTLE? | Swaphappy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-05-2003 09:00 AM |
How Do Ya MAKE IT PLAY THE SONG FASTER? | The Zone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 10-22-2002 10:53 PM |
Faster Processor=Faster Bounce??? | smashannon | Pro Tools TDM Systems (Mac) | 8 | 08-28-2000 10:36 PM |
