Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 01-14-2019, 08:49 AM
creativecontrol's Avatar
Default Re: Setting to make plugin selection in DAW follow channel selection?
Greetings,
Please see the following thread:
http://duc.avid.com/showthread.php?t=402742
2018.12 has some breakages for Windowing on S6 when used in conjunction with S6 version 18.3. The current recommendation is to use Pro Tools 18.10 with S6 18.3 until the new S6 release is available.
best,
Jeff
Jeff Komar
Old 01-14-2019, 09:14 AM
kaonashi kaonashi is offline
Thanks Jeff much appreciated, when can we expect a update for the s6? Will use this workaround in the meantime.
Cheers
Old 01-15-2019, 11:46 AM
EddieJones's Avatar
Its weeks not months away....
Pan and plugin windows follow selection GuidoHelbling Post - Surround - Video 13 09-25-2014 01:38 PM
Random Plugin Selection/Plugin Selection Shortcut issues thebeatless Pro Tools HDX & HD Native Systems (Mac) 10 08-05-2014 10:52 PM
C8 Track selection Follow daslicht ProControl, Control|24, Command|8 4 01-11-2011 06:11 AM
mix window does not follow c24 send selection Serge Perron ICON & C|24 0 10-19-2010 06:37 PM
Play/Edit Marker stopped follow timeline selection stern 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-22-2007 11:30 PM
