  #31
Old 07-02-2019, 10:56 AM
Southsidemusic's Avatar
Default Re: I fell for the Bass Fingers plugin and it doesn’t install ..
Rob, thats Great Neeeeews after two days of struggles
I am d/l right now and as it is already evening here we can talk tomorrah and compare success or defeat
Again Thank you Rob and I am really thankful for your involvement.
Best Regards
Christopher
South Side Music Group
WEBHOME
  #32
Old 07-02-2019, 04:43 PM
unkJE unkJE is offline
Originally Posted by Southsidemusic View Post
bought Bass Fingers as it was 25 bucks which is nada!!!
Thanks for the heads-up, Chris!
If nada’s too expensive for others – Bass Finger is US $22.05 after login at Audio Deluxe
Pro Tools 2019.6/10.3.10 and 12.5.1 HD - Studio One 4 Pro - Win7 64 Ultimate (SP1) – Lenovo W520 ThinkPads & 433830U Docks – Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32
  #33
Old 07-02-2019, 04:44 PM
Originally Posted by xrekcor View Post
I suggest downloading the Bass Fingers without the sample library and once it's completed, download the sample library separately from this link.
https://www.waves.com/downloads/sample-libraries
Thanks Rob!
Last edited by unkJE; 07-02-2019 at 06:29 PM. Reason: will try the Offline Installer
  #34
Old 07-02-2019, 07:47 PM
xrekcor's Avatar
xrekcor xrekcor is offline
hey Folks,
well it is all installed now I believe.... once I downloaded the samples, I located the folder locations on my MBP where the samples appeared greyed out (refer to the image I posted earlier) copied and pasted the uncompressed sample folders in there. Although you could place them where you like I believe just have to point Bass Finger to the right place.
Ok this may be a dumb question so ill ask it here.... with the sample libraries you don't have a list of samples you can choose, but the plugin selects them depending on the settings you choose within the plugin itself? hence why Chris asked earlier if I only DL'd the plug and not the SD and HD samples how was I getting sound when we were having issues installing (seems we were not the only ones)
I would seem to me that the initial failed installs did install a large chunk of the samples and why they appeared greyed out... maybe when I installed the plug by itself I could access those greyed out samples somehow. Just not sure how these sample are meant to work so I can confirm it is installed correctly.... Sorry if that all sound a lil confusing...
have to say I'm loving the sounds of this plug
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2019.6-23.# - HEAT applied, Cubase 9.5,
Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
  #35
Old 07-02-2019, 07:50 PM
xrekcor's Avatar
Nps Chris pleased to be of help mate.
Rob
  #36
Old 07-02-2019, 07:57 PM
xrekcor's Avatar
Nps happy to help
Originally Posted by unkJE View Post
Thanks Rob!
Rob
  #37
Old 07-02-2019, 11:53 PM
Yep - select a Preset from the Menu.
My (Windows) installation:
After extracting the WinZip (Bass-Fingers-samples-HD), put the Bass Fingers HD Folder here:
C:\Program Files (x86)\Waves\Data\Instrument Data\Waves Sample Libraries
Downloaded the (5.66 GB) Offline Installer (thanks martthie_08 for Post #26 with links). Installed Bass Fingers plug-in (it includes the AAX/Vst/VST3 WavesShells).
Held down the Shift Key during Pro Tools launch to check the “Rescan all Plug-Ins” option, to add Bass Fingers.
Once Bass Fingers was instantiated, Pro Tools asked for location of Waves Bass Fingers samples (see pic 1)
Takes a while to load the HD samples – red line at top – (see pic 2)
Once samples have loaded, hit the ‘Load’ button to the left of the ‘Save’ button at the top RHS to select a Preset (see pic 3)
Last edited by unkJE; 07-04-2019 at 08:11 AM. Reason: Thanks Rob! Changed 'sample' to 'Preset'
  #38
Old 07-03-2019, 04:29 AM
xrekcor's Avatar
Hey mate, that third image is the preset list.... it's a seperate folder... samples and presets are 2 seperate things.
I also found out that the 2 sample folders SD and HD are exactly the same except the SD folder has been compressed.... and hence will place more load on your CPU than the HD uncompressed version. recommended if you have the space run the HD version.
Rob
  #39
Old 07-03-2019, 05:49 AM
martthie_08 martthie_08 is offline
Hey Marthie Those links look interesting... what are they a Waves offline installer?
it is basically the installation data for all their Plugins, minus the Sampler Instruments. You'll still need Waves Central to actually install and authorise everything!
  #40
Old 07-03-2019, 05:50 AM
Thanks Rob!
Heaps to choose from - plenty to tweak ..... lottsa fun for a pittance!
HTML code is On
New Bass Fingers, for all you Bass Slapper fans simon.a.billington Virtual Instruments 0 06-19-2019 05:37 AM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
bass amp plugin- what do you use? remis General Discussion 21 12-05-2010 08:25 PM
Guitar/bass synthesizer Plugin ? Jayoel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-26-2009 09:50 AM
Bass Amp Simulator plugin Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-16-2008 06:13 AM
