Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 02-03-2018, 03:43 PM
hixonjames hixonjames is offline
Default Master Module Won't Boot
I have a support ticket in, but haven't heard from anybody yet. I figured I'd try this as well...
My Master Module is not booting. After pressing the power button (or connecting power) the cooling fan comes on and stays on, and nothing appears on the touchscreen. All other modules have the purple "Waiting for Network" lights.
This has happened a few times before, but I've always been able to get back up and running eventually. Several weeks ago, it began a behavior where, if I had to shut down and restart for some reason, it would not boot immediately after shutting down. However, after some time with the power off (sometimes an hour; often overnight), it would boot just fine. This time, I can't get it to boot at all, even after an overnight rest.
I have tried to do a system restore, but holding F2 (PC Keyboard, not Mac) on power-up does nothing. Ctrl+Alt+Del also does nothing.
I'm out of ideas.
James Hixon
Pro Tools | HDX 2019.5
S6 M40 19.5
Mac Pro (Late 2013) - Mojave 10.14.5
3 GHz 8-Core Intel Xeon E5
64 GB RAM
Old 02-03-2018, 04:33 PM
Default Re: Master Module Won't Boot
After disconnecting the Master Module completely (and removing it from the console frame) for 20 minutes, I reconnected it, powered it up, and it booted.
I don't know if this procedure will continue to work, but I will now attempt a system restore in hopes that it will fix my issues.
James Hixon
S6 M40 19.5
64 GB RAM
Old 02-03-2018, 05:31 PM
EddieJones's Avatar
Other than a hardware fault with the motherboard, it could be a bad power connection (taking it out of the chassis may have helped)
Did you get a support ticket number ?
Old 02-04-2018, 05:02 AM
Case# 03394817
I wondered about a bad power connection. I tried using a different lead from the power supply to the module, but nothing changed. The other modules plugged into that power supply (Transport and lower part of the Master) seem to be operating properly. Also, would the fan still come on if the power connection was faulty?
After the one time I got it to boot last night, I copied my user preferences and soft key appset to a flash drive. I haven't been able to get it to boot since. I left it out of the chassis overnight - still nothing.
James Hixon
S6 M40 19.5
64 GB RAM
Old 02-05-2018, 01:06 PM
EddieJones's Avatar
I spoke with CS about this and hopefully they have sorted you ?
Old 02-07-2018, 09:52 AM
They have. Louis has sent me a replacement that should arrive today.
Thanks for looking out for me, Eddie.
James Hixon
S6 M40 19.5
64 GB RAM
Old 02-09-2018, 12:01 PM
Correction: A replacement was not shipped as they are out of stock. Logistics is looking for one to send me for delivery hopefully tomorrow.
James Hixon
S6 M40 19.5
64 GB RAM
Best way to wire footswitch to Master Module for talkback ? WildHoney Pro Tools | S6 3 09-18-2017 07:23 PM
S6 not recognizing any modules, including master module polyh3dron Pro Tools | S6 4 06-30-2016 06:14 PM
Master Module FAN NOISE rcutz Pro Tools | S6 11 07-29-2015 06:39 AM
GUID or Master Boot Record? JoyMODE101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-05-2011 06:29 AM
Apple Partition, Master Boot, GUID?????? whitelabellt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-01-2009 12:34 AM
