Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 04-02-2013, 10:57 AM
maxlor314 maxlor314 is offline
Default Mbox Pro Headphone Outs Left Channel Only
Hi, I have an Mbox Pro (third generation) that I use with a mac, and I'm generally happy with it. Today I tried to use the headphone outs for the first time, and I only get a signal coming out the left channel.
I tried both Headphone A and headphone B. I tried sending the signal from different sources. I also tried uninstalling the Mbox software, trashing preferences, and re-installing the latest version with the latest firmware. The meters in the Mbox software show a stereo signal, but it's still only coming out of the left channel.
Has anyone else encountered this? Does anyone know a fix?
THanks
Max
Old 04-03-2013, 04:06 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Mbox Pro Headphone Outs Left Channel Only
THanks
Max
Have you tried another set of headphones? tried the headphones on another device? given the headphone socket a clean?
If the output in pro tools shows stereo level then the headphones should also be stereo-both-channels etc. would most likely be dry connection somewhere and not software related.
Are you able to connect speakers to the outputs to check stereo is working ok?
chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 04-04-2013, 04:53 AM
Hi Chris, thanks for the advice. It was the headphones after all. More specifically, it was the 1/4 in. adapter on my Audio Technica M50.
Luckily, my office has several pairs, so I tried the 1/4 inch adapter from a different pair and it worked! Look at the difference in the 2 connectors. This is from the same headphone model, but I bought them a couple years apart:
Strange CoreAudio issue - right channel information getting into left channel -JK- Pro Tools 9 5 01-10-2011 08:42 AM
Left channel output louder in Mbox 1, please help. pcmusicpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-14-2008 09:40 AM
Lost the Left Channel OUT of my Mbox Deirdre B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-30-2008 10:19 AM
Mbox Headphone Output - Only one Channel dvottero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-19-2006 06:40 PM
Why does the Mbox have two headphone outs if... joesmohello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-08-2003 12:13 AM
