Old 01-24-2011, 04:32 AM
lumcas lumcas is offline
Default Minor problem while saving a session
Hello, just a minor glitch but it drives me nuts anyway, I tried to search the forum but haven't found anything similar. Whenever I want to save a PT session (003, PT 9.0.1, OSX 10.6.5) I just hit command+s and a window always pops up saying "The disk copy of the session was changed since you last opened or saved it. Do you want to save anyway?" I just hit ok and everything works as expected, it's not an error message, session saves properly and I can continue working but I'm wondering what's going on. I know it's nothing serious and it doesn't take a log time to hit return key, so not a big deal really, but I'm curious.
I am on PT since version 5 and have never seen anything like that.
Thank you for the answer.
lumcas
Old 01-25-2011, 01:36 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Minor problem while saving a session
lumcas
Command+S as always been "save as" and it will ask if you want to overwrite the currently saved version.
Not sure if you do!! but you should always save with an incremental save (song 1 / song 2 / song 3 etc) at least every 30 minutes, to sensibly work safe with auto back-ups, and to make sure you have a good working session to revert to.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 01-25-2011, 03:49 AM
Thank you Chris for your input, although it doesn't help much. Command+S has always been plain save command and it shouldn't ask you anything, just save the current session. There is "Save as" command right under the save command in the file menu and that's obviously different.
I've been working on many HD, LE rigs for years and have never encountered this behavior, you shold just hit save and move on.
Anyway. don't know if it helps, but here's the screen shot of the window
http://dl.dropbox.com/u/8676181/Screenshot.jpg
The other suggestion - incremental save - saved my ass many times over the years. Good one!
Thank you again Chris.
lumcas
Old 01-25-2011, 12:44 PM
formfunction formfunction is offline
lumcas
That is strange... command-s is hit hundreds of times an hour when I am working and I have never seen anything like that? Does this happen on all sessions?
Is your disk allocation having anything to do with it? I notice you are using a "copy" is why I ask.
Does it do it even after you do a "save as"?
hmmmmmm
Old 06-30-2011, 04:37 PM
jasonity jasonity is offline
lumcas
I've had the exact same problem. I'm running PT HD 9.0.3 on Mac OSX 10.6.4. I'm guessing that you're running your session on a local drive. I've only seen the problem going to a Unity workspace. It hasn't prompted me if I'd like to save a new version since I saved when I work on a local drive. I'm guessing it's a bug. I wonder how many other people are experiencing the same problem.
J
Old 08-07-2019, 02:47 AM
analogonkel analogonkel is offline
I found this old thread because I had the same problem with PT HD 12.7.1 on Windows 10.
Now I encountered that this happens when an other program is accessing the hard drive with the PT session on it (sorry for my bad English : )
In this case it was a program which makes automatically backups from my hard drives.
Maybe this helps someone.
Matteo Bohé -
TONMEISTER.KOELN
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 doubtful guest Pro Tools TDM Systems (Mac) 1 02-06-2013 03:42 AM
MINOR PROBLEM WITH PROTOOLS CAN SoME ONE HELP ME KineticRdy4War Pro Tools M-Powered (Win) 2 04-19-2007 05:34 PM
Minor problem....Can't access 'manual' from session... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-06-2003 11:33 AM
? saving session as/saving copy of session in surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-05-2002 10:24 AM
Saving a session on CD-ROM!!!! black magic General Discussion 2 10-28-2000 10:12 AM
