Old 05-30-2008, 05:40 AM
sureno sureno is offline
Default How do i merge stereo to a single mono?
tried doing a search on the forum but that led no where, could some one briefly explain the procedure
thanks
3.2 dual quad 4gb mac pro 10.5.6, logic 8.02/ PT8 003 factory through RM2's
Old 05-30-2008, 06:15 AM
Phil Ogden Phil Ogden is offline
Default Re: How do i merge stereo to a single mono?
You could 'Bounce To Disk' and select 'Mono (summed)' as the output format.
http://www.myspace.com/philogg
Old 05-30-2008, 07:54 AM
cool
Old 05-30-2008, 08:00 AM
flommer flommer is offline
Or pan both left and right tracks to center, bus to a mono track and record the result. Puts the mono track back in the mix right away..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 05-30-2008, 08:13 AM
thanks guys, the reason i ask is so i don't run out of tracks, MPTK is on my list but not at the top of priorities
Old 05-30-2008, 10:09 AM
Shawn Simpson Shawn Simpson is offline
You didn't specify what you're trying to record, but you might just want to split the stereo tracks into mono and deleting one side. In some cases, summing the stereo tracks can cause pretty bad phasing issues and you'd be better off just using one side or the other.
Old 05-30-2008, 10:53 AM
yeah what iv just tried is taking the left side of a kick and using that, seems to do the trick
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
Stereo tracks to single mono output... what's happening? PTPerson Pro Tools TDM Systems (Mac) 4 02-22-2011 02:39 PM
Conver stereo track to SINGLE mono track markolone Pro Tools M-Powered (Win) 1 07-30-2010 07:09 PM
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 09:01 AM
